This guide describes how to deploy OpenIAM to a private (not AWS, GKE) Kubernetes cluster via Helm, but without Terraform. This type of deployment is not recommended due to the number of Helm variables.
Before starting the installation process, please make sure that the following prerequisites are in place.
- Access to Kubernetes cluster (
kubectlconfigured on installer VM) is active. - Helm 3 is installed and configured.
- Docker (if building/pulling images locally) is installed or the access to container registry is live.
- Network connectivity to remote DB (if using remote database) is active.
- Appropriate credentials for Harbor/container registry and DB users are in place.
- There is an admin (root) access to the private Kubernetes cluster with the required permissions to create cluster-level resources.
Installer VM preparation
Recommended OS: Ubuntu 20.04/22.04 (commands below follow Ubuntu syntax). Ensure that SSH key access and root privileges are available.
Installing required utilities
Before installing OpenIAM there are several utilities that must be installed, such as Docker, Helm, and kubectl. Use the exact commands below or adapt them to your environment.
Installing Docker
Use the commands below to install Docker.
sudo mkdir -p /etc/apt/keyringscurl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo gpg --dearmor -o /etc/apt/keyrings/docker.gpgecho "deb [arch=$(dpkg --print-architecture) signed-by=/etc/apt/keyrings/docker.gpg] https://download.docker.com/linux/ubuntu $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/docker.list > /dev/nullsudo apt-get update -ysudo chmod a+r /etc/apt/keyrings/docker.gpgsudo apt-get install docker-ce docker-ce-cli -y
Installing Helm
Use the following commands to install Docker.
curl -fsSL -o get_helm.sh https://raw.githubusercontent.com/helm/helm/main/scripts/get-helm-3chmod 700 get_helm.sh./get_helm.sh
Installing kubectl
Use the following commands to install kubectl.
curl -LO https://dl.k8s.io/release/v1.25.6/bin/linux/amd64/kubectlsudo install -o root -g root -m 0755 kubectl /usr/local/bin/kubectlkubectl --version
Preparing OpenIAM deployment directory
Star with creating a base directory, then log in to registry, clone repo and check out required release tag.
sudo mkdir -p /usr/local/openiamcd /usr/local/openiamgit clone https://bitbucket.org/openiam/kubernetes-docker-configuration.gitcd kubernetes-docker-configuration/git checkout RELEASE-4.2.1.16./setup.shdocker login registry.openiam.com
Deployment options
OpenIAM can be installed using local MariaDB (Helm chart packaged) or using remote MySQL/PostgreSQL. Use the appropriate configuration in setup-no-tf.sh. Key variables to set in setup-no-tf.sh are given in the table below.
| Variable | Description | Example |
BUILD_ENVIRONMENT | Environment type (dev/prod) | prod |
OPENIAM_VERSION_NUMBER | OpenIAM release version | 4.2.1.16 |
APP_NAME | Application name prefix for Helm releases | test2021 |
ROOT_PASSWORD | Database root password (used for local DB chart) | passwd00 |
openiam.database.jdbc.openiam.host | Database host for OpenIAM schema | 10.0.0.5 |
openiam.database.type | Database type: MariaDB / Postgres | MariaDB |
Pre-deployment checklist
✅ kubectl configured on installer VM.
✅ Helm installed and repository updated.
✅ Registry credentials are available.
✅ Database reachable and user created.
✅ Required database ports open between cluster and DB.
✅ Values.yaml reviewed and customized if needed.
✅ Existing DB (if migrating) is backed up.
Installing OpenIAM using local MariaDB
Edit setup-no-tf.sh and set the variables described above. For local DB, ensure MariaDB chart version is set and not commented.
Use the commands below to edit the file:
vi setup-no-tf.sh
... to set the variables:
BUILD_ENVIRONMENT="dev"OPENIAM_VERSION_NUMBER="4.2.1.16"APP_NAME="test2021"
... to run Installation setup, it will prompt for registry credentials:
./setup-no-tf.sh
... to monitor.
kubectl get pods -n <namespace>
Installing OpenIAM using remote MySQL database
To install OpenIAM using remote MySQL database, you will need to update DB host, port, database type and Hibernate dialect. Comment out local MariaDB Helm install block to avoid deploying local DB as follows.
openiam.database.jdbc.openiam.host=<DB_HOST>openiam.database.jdbc.openiam.port=3306openiam.database.jdbc.activiti.host=<DB_HOST>openiam.database.jdbc.activiti.port=3306openiam.database.type=MariaDBopeniam.database.jdbc.hibernate.dialect="org.hibernate.dialect.MySQLDialect"
Next, comment local MariaDB block in setup-no-tf.sh with the following commands.
#MARIADB_CHART_VERSION=#helm upgrade --install "${APP_NAME}-database" openiam/mariadb -f .deploy/mariadb.values.yaml --version "${MARIADB_CHART_VERSION}" --set auth.rootPassword="${ROOT_PASSWORD}" --set initdbScriptsConfigMap="mariadb-initdbscripts" --set openiam.bash.log.level="warn"
Afterwards, run installation setup, it will prompt for registry credentials.
./setup-no-tf.sh
Installing OpenIAM using remote PostgreSQL
To install OpenIAM using remote PostgreSQL database, set database type to Postgres and use PostgreSQL dialect with the following command. Ensure network access and DB user with required privileges.
openiam.database.jdbc.openiam.host=<DB_HOST>openiam.database.jdbc.openiam.port=5432openiam.database.jdbc.activiti.host=<DB_HOST>openiam.database.jdbc.activiti.port=5432openiam.database.type=Postgresopeniam.database.jdbc.hibernate.dialect="org.hibernate.dialect.PostgreSQLDialect"
Then comment local MariaDB block in setup-no-tf.sh as follows.
Finally, run Installation setup, it will prompt for registry credentials
./setup-no-tf.sh
Post-install verification
After a successful deployment, make sure to verify pods, services, ingress/rProxy and logs. with the following useful commands.
kubectl get pods -Akubectl get svc -Akubectl logs <pod> -n <namespace>kubectl describe pod <pod> -n <namespace>To find rproxy service and expose to external network:kubectl get svc | grep prox
Troubleshooting
If ElasticSearch-curator or bootstrap jobs fail, use the following commands to cleanup and retry.
kubectl delete jobs --allhelm ls | grep rabbithelm delete <app>-rabbitmqkubectl get pvc | grep rabbitkubectl delete pvc data-<app>-rabbitmq-0helm delete <app>-configmapkubectl delete job <app>-vault-bootstrap-job
After, re-run the setup.
./setup-no-tf.sh
