This type of installation is suitable for both el8 RHEL / CentOS version. Also, during the installation you will be prompted to install MariaDB RDBMS. This is suitable for Demo and POC installations. If you have already had the database server, you should answer N for the prompt.
  1. Download the following files to a server that has internet access.
curl https://download.openiam.com/release/enterprise/4.2.1.16/rpm/openiam-4.2.1.16.noarch.x86_64.rpm --output openiam-4.2.X.noarch.x86_64.rpm
curl https://download.openiam.com/release/enterprise/4.2.1.16/dependencies/el8/openiamrepo.tar.gz --output openiamrepo.tar.gz
curl https://download.openiam.com/release/enterprise/4.2.1.16/binaries/frontend.tar.gz --output frontend.tar.gz
curl https://download.openiam.com/release/enterprise/4.2.1.16/binaries/backend.tar.gz --output backend.tar.gz
curl https://download.openiam.com/release/enterprise/infra/httpd-libs.tar.gz --output httpd-libs.tar.gz
curl https://download.openiam.com/release/enterprise/4.2.1.16/rpm/openiam-4.2.1.16.noarch.x86_64.rpm --output openiam-4.2.X.noarch.x86_64.rpm --output openiam-4.2.X.noarch.x86_64.rpm
curl https://download.openiam.com/release/enterprise/4.2.1.16/dependencies/el9/openiamrepo.tar.gz --output openiamrepo.tar.gz
  1. Create folder /usr/local/openiam on the server.
  2. Copy the following files that were downloaded earlier to /usr/local/openiam
    • backend.tar.gz;
    • frontend.tar.gz;
    • openiamrepo.tar.gz;
    • httpd-libs.tar.gz.
  3. Install from the RPM using the following command.
    You will see output like the following.
    openiam/
    openiam/connectors/
    openiam/connectors/shutdown.sh
    openiam/connectors/start.sh
    openiam/env.conf
    openiam/services/
    openiam/services/shutdown.sh
    openiam/services/start.sh
    openiam/source-adapters/
    openiam/source-adapters/shutdown.sh
    openiam/source-adapters/start.sh
    openiam/utils/
    openiam/utils/autodb.sh
    openiam/utils/autoinit.sh
    openiam/utils/cluster_healthcheck.sh
    openiam/utils/curator/
    openiam/utils/curator/init.sh
    openiam/utils/elasticsearch/
    openiam/utils/elasticsearch/default.policy.diff
    openiam/utils/elasticsearch/elasticsearch
    openiam/utils/elasticsearch/elasticsearch.service
    openiam/utils/elasticsearch/init.sh
    openiam/utils/elasticsearch/jvm.options
    openiam/utils/flyway/
    openiam/utils/flyway/V0.0.0.0.000__initialization.sql.mssql.m4
    openiam/utils/flyway/V0.0.0.0.000__initialization.sql.mysq.m4
    openiam/utils/flyway/V0.0.0.0.000__initialization.sql.mysql.m4
    openiam/utils/flyway/V0.0.0.0.000__initialization.sql.mysql.rds.m4
    openiam/janusgraph/javadocs/package-list
    openiam/janusgraph/javadocs/index.html
    openiam/janusgraph/javadocs/constant-values.html
    openiam/janusgraph/javadocs/help-doc.html
    openiam/janusgraph/javadocs/allclasses-frame.html
    openiam/janusgraph/javadocs/allclasses-noframe.html
    openiam/janusgraph/javadocs/stylesheet.css
    openiam/janusgraph/javadocs/overview-summary.html
    /var/tmp/rpm-tmp.ElioLH: line 9: openiam: Is a directory
    No, user openiam does not exist. creating
    useradd: warning: the home directory already exists.
    Not copying any file from skel directory into it.
    shell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
    The server will be restarted in 1 min to apply ulimit settings ...
    Shutdown scheduled for Wed 2023-11-22 21:20:46 UTC, use 'shutdown -c' to cancel.
    At this point the VM will reboot to initialize variables that are needed for stack components such as Elasticsearch.
  4. Execute the initialization step the openiam-cli. During this step the system will be installing and configuring the various components that make up OpenIAM. Please follow the instructions on the screen.
  5. The first question: Does this box have Internet access? [y/n]. Please enter N
  6. You will be asked about installing MariaDB as a default database. Would you like to install MariaDB RDBMS locally? Please answer Y if you would like to use local MariaDB RDBMS as a database server (good choice for quick and simple installation, like demo or POC or small size production platform (up to 500 active users)). Otherwise, please, answer N.
7.1. If you answer 'Y' for MariaDB installation, installer will prepare all files and after will ask you some details:
  • Enter current password for root (enter for none): -> Press: 'Enter' button
  • Set root password? [Y/n] -> Press 'y' button and after 'Enter'
  • New password: -> Type password for the root user. You will need it later during the installation.
  • Re-enter new password: -> Type the password for the root user as on the previous
  • Remove anonymous users? [Y/n] -> Press 'y' button and after press 'Enter'.
  • Disallow root login remotely? [Y/n] -> Press 'y' button and after press 'Enter'.
  • Remove test database and access to it? [Y/n] -> Press 'y' button and after press 'Enter'.
  • Reload privilege tables now? [Y/n] -> Press 'y' button and after press 'Enter'.
  1. The installation process will continue. The Cassandra backend as a Graph storage will be installed. Please, be patient as this process can take 4-5 minutes. If you see the ugly exception below, ignore it. This is a byproduct of Cassandra taking some time to start (this will be addressed in an upcoming release).
-- StackTrace --
at org.apache.cassandra.dht.Murmur3Partitioner.describeOwnership(Murmur3Partitioner.java:284)
at org.apache.cassandra.service.StorageService.getOwnershipWithPort(StorageService.java:5166)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at sun.reflect.misc.Trampoline.invoke(MethodUtil.java:72)
at sun.reflect.GeneratedMethodAccessor2.invoke(Unknown Source)
at sun.reflect.misc.MethodUtil.invoke(MethodUtil.java:276)
at com.sun.jmx.mbeanserver.StandardMBeanIntrospector.invokeM2(StandardMBeanIntrospector.java:112)
at com.sun.jmx.mbeanserver.StandardMBeanIntrospector.invokeM2(StandardMBeanIntrospector.java:46)
at com.sun.jmx.mbeanserver.MBeanIntrospector.invokeM(MBeanIntrospector.java:237)
at com.sun.jmx.mbeanserver.PerInterface.getAttribute(PerInterface.java:83)
at com.sun.jmx.mbeanserver.MBeanSupport.getAttribute(MBeanSupport.java:206)
at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.getAttribute(DefaultMBeanServerInterceptor.java:647)
at com.sun.jmx.mbeanserver.JmxMBeanServer.getAttribute(JmxMBeanServer.java:678)
at javax.management.remote.rmi.RMIConnectionImpl.doOperation(RMIConnectionImpl.java:1445)
at javax.management.remote.rmi.RMIConnectionImpl.access$300(RMIConnectionImpl.java:76)
at javax.management.remote.rmi.RMIConnectionImpl$PrivilegedOperation.run(RMIConnectionImpl.java:1309)
at javax.management.remote.rmi.RMIConnectionImpl.doPrivilegedOperation(RMIConnectionImpl.java:1401)
at javax.management.remote.rmi.RMIConnectionImpl.getAttribute(RMIConnectionImpl.java:639)
at sun.reflect.GeneratedMethodAccessor5.invoke(Unknown Source)
at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:357)
at sun.rmi.transport.Transport$1.run(Transport.java:200)
at sun.rmi.transport.Transport$1.run(Transport.java:197)
at java.security.AccessController.doPrivileged(Native Method)
at sun.rmi.transport.Transport.serviceCall(Transport.java:196)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:573)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:834)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.lambda$run$0(TCPTransport.java:688)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:687)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:750)
Waiting for cassandra
  1. The installer will ask a number to questions during the initialization process. For most questions, a default value has been provided to simplify the effort for users new to OpenIAM. The section which requires input from the installer is marked with the following message in the console: =============== CRITICAL SECTION ===============
Set OpenIAM username for openiam schema, default: idmuserThis is DB username that will be used to manage the openiam OpenIAM schema. This is the primary schema in the solution data related to OpenIAM are stored. Username will be used by the OpenIAM application to communicate with database.
The default value is idmuser.
Set OpenIAM password for openiam schema, default: idmuserThis is the password that will be used for username which was provided in the previous step. The default value is: idmuser
Set OpenIAM username for activiti schema.
For MySQL it will be the same as for openiam, default: idmuser
This is DB username that will be used to manage the activiti schema. User will be used by OpenIAM application to communicate with the database.
Default value is idmuser.
Set OpenIAM password for activiti schema.
This is the password that for the user associated with the activiti schema.
Memory cache
  • End user web session.
  • Database object cache.
Initialize database schema
Use default value if this is new installation. If you are doing an update, specify your current (before update) version here, like 4.1.11.0, default: 0.0.0.0If this installation is an upgrade from an existing deployment, then the current version is important as it will determine which scripts need to be applied to upgrade the schema to the current version. If this is a new deployment, you can leave this blank
This is the name of the OpenIAM core database. If using MariaDB, this is most likely to be openiam, default: openiamThis question provides the option to choose the primary database schema. You should leave this blank and let it default to openiam. This value should only be changed if the scripts have been altered by the customer.
Possible values: MySQL, Postgres, MSSQL, Oracle. Type of the database that you are going to use with OpenIAM. The RDBMS have to be already installed, default: MySQLSelect the type of database that you will be using as the OpenIAM product repository. You can leave this blank if you will be using either MariaDB or MySQL. If you are using either PostgreSQL, Oracle or Microsoft SQL server, enter one the following values based on your database type: postgres, oracle, mssql.
Do you want to initialize OpenIAM Schema and Users? Select this if you are not created schema and users in RDBMS yet. Super user (root) password will be required [y/n]If Y then installer will create schemas in database and corresponded RDBMS users as well. For Oracle/MSSQL it will generate an SQL script that must be performed manually.
Enter username for Super user (for MySQL this is root), default: rootThe installer needs a super user account or equivalent which has the privileges to create new schema, users, tables, etc.
Enter password for super user (sa or root, depend on the DB type), default:Enter the password for account provided in the last step.
This is the hostname of where the OpenIAM core database is., default: localhostEnter the host or DNS name of the server where the primary OpenIAM database will be deployed.
This is the hostname of where the OpenIAM Activiti database is., default: localhostEnter the host or DNS name of the server where the workflow database will be deployed.
This is the port of where the OpenIAM Activiti database is. If using MariaDB, this is most likely 3306, default: 3306Enter the port number used by the database server hosting the workflow database.
  • C:\Users\Asus>scp openiam-4.2.1.16.noarch.x86_64.rpm root@10...*:/usr/local/openiam/
  • The authenticity of host '10... (10...)' can't be established.
  • ECDSA key fingerprint is SHA256:5pP7vxJnDzbQ+Xg1VANjSBYL7HboHyM4RqFKW4qHkPU.
  • Are you sure you want to continue connecting (yes/no/[fingerprint])?`
  • Warning: Permanently added '10...*' (ECDSA) to the list of known hosts.
  • root@10...*'s password:
  • openiam-4.2.1.16.noarch.x86_64.rpm 23% 133MB 1.4MB/s 05:12 ETA`
OpenIAM Login page .
Content Provider NameYou can think of a content provider as an “alias” which represents a domain. This is described in more detail in the OpenIAM documentation. For this setup, please enter a value such as: Default CP
Internet on box
Type N and press Enter.
