This installation type is suitable for the servers without Internet access (Server from which you can't reach OpenIAM website).
This type of installation is suitable for both el8 RHEL / CentOS version. Also, during the installation you will be prompted to install MariaDB RDBMS. This is suitable for Demo and POC installations. If you have already have the database server you should answer 'N' for the prompt.
  1. Download the following files to a server that has internet access.
    curl https://download.openiam.com/release/enterprise/4.2.1.8/rpm/openiam-4.2.1.8.noarch.x86_64.rpm --output openiam-4.2.X.noarch.x86_64.rpm
    curl https://download.openiam.com/release/enterprise/4.2.1.8/dependencies/el8/openiamrepo.tar.gz --output openiamrepo.tar.gz
    curl https://download.openiam.com/release/enterprise/4.2.1.8/binaries/backend.tar.gz --output backend.tar.gz
    curl https://download.openiam.com/release/enterprise/4.2.1.8/binaries/frontend.tar.gz --output frontend.tar.gz
    curl https://download.openiam.com/release/enterprise/infra/httpd-libs.tar.gz --output httpd-libs.tar.gz
  2. Create folder /usr/local/openiam on the server.
  3. Copy the following files that were downloaded earlier to /usr/local/openiam
    • backend.tar.gz
    • frontend.tar.gz
    • openiamrepo.tar.gz
    • httpd-libs.tar.gz
  4. Install from the RPM using command:
    You will see output similar to the following:
    openiam/
    openiam/connectors/
    openiam/connectors/shutdown.sh
    openiam/connectors/start.sh
    openiam/env.conf
    openiam/services/
    openiam/services/shutdown.sh
    openiam/services/start.sh
    openiam/source-adapters/
    openiam/source-adapters/shutdown.sh
    openiam/source-adapters/start.sh
    openiam/utils/
    openiam/utils/autodb.sh
    openiam/utils/autoinit.sh
    openiam/utils/cluster_healthcheck.sh
    openiam/utils/curator/
    openiam/utils/curator/init.sh
    openiam/utils/elasticsearch/
    openiam/utils/elasticsearch/default.policy.diff
    openiam/utils/elasticsearch/elasticsearch
    openiam/utils/elasticsearch/elasticsearch.service
    openiam/utils/elasticsearch/init.sh
    openiam/utils/elasticsearch/jvm.options
    openiam/utils/flyway/
    openiam/utils/flyway/V0.0.0.0.000__initialization.sql.mssql.m4
    openiam/utils/flyway/V0.0.0.0.000__initialization.sql.mysq.m4
    openiam/utils/flyway/V0.0.0.0.000__initialization.sql.mysql.m4
    openiam/utils/flyway/V0.0.0.0.000__initialization.sql.mysql.rds.m4
    openiam/janusgraph/javadocs/package-list
    openiam/janusgraph/javadocs/index.html
    openiam/janusgraph/javadocs/constant-values.html
    openiam/janusgraph/javadocs/help-doc.html
    openiam/janusgraph/javadocs/allclasses-frame.html
    openiam/janusgraph/javadocs/allclasses-noframe.html
    openiam/janusgraph/javadocs/stylesheet.css
    openiam/janusgraph/javadocs/overview-summary.html
    /var/tmp/rpm-tmp.ElioLH: line 9: openiam: Is a directory
    No, user openiam does not exist. creating
    useradd: warning: the home directory already exists.
    Not copying any file from skel directory into it.
    shell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
    The server will be restarted in 1 min to apply ulimit settings ...
    Shutdown scheduled for Wed 2023-11-22 21:20:46 UTC, use 'shutdown -c' to cancel.
    At this point the VM will reboot to initialize a variables that are needed for stack components such as Elasticsearch
  5. Execute the initialization step the openiam-cli. During this step the system will be installing and configuring the various components that make up OpenIAM. Please follow the instructions on the screen.
  6. The first question: Does this box have Internet access ? [y/n]. Please enter N
  7. You will be asked about installing MariaDB as a default database. Would you like to install MariaDB RDBMS locally? Please answer Y if you would like to use local MariaDB RDBMS as a database server (good choice for quick and simple installation, like demo or POC or small size production platform (up to 500 active users)). Otherwise, please, answer N.
7.1. If you answered 'Y' for MariaDB installation, installer will prepare all files and after will ask you about some details:
  • Enter current password for root (enter for none): -> Press: 'Enter' button
  • Set root password? [Y/n] -> Press 'y' button and after 'Enter'
  • New password: -> Type password for the root user. You will need it later during the installation.
  • Re-enter new password: -> Type the password for the root user as on the previous
  • Remove anonymous users? [Y/n] -> Press 'y' button and after press 'Enter'.
  • Disallow root login remotely? [Y/n] -> Press 'y' button and after press 'Enter'.
  • Remove test database and access to it? [Y/n] -> Press 'y' button and after press 'Enter'.
  • Reload privilege tables now? [Y/n] -> Press 'y' button and after press 'Enter'.
  1. The installation process will continue. The Cassandra backend as a Graph storage will be installed. Please, be patient as this process can take 4-5 minutes. If you see the ugly exception below, ignore it. This is a byproduct of Cassandra taking some time to start. (This will be addressed in an upcoming point release.)
-- StackTrace --
at org.apache.cassandra.dht.Murmur3Partitioner.describeOwnership(Murmur3Partitioner.java:284)
at org.apache.cassandra.service.StorageService.getOwnershipWithPort(StorageService.java:5166)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at sun.reflect.misc.Trampoline.invoke(MethodUtil.java:72)
at sun.reflect.GeneratedMethodAccessor2.invoke(Unknown Source)
at sun.reflect.misc.MethodUtil.invoke(MethodUtil.java:276)
at com.sun.jmx.mbeanserver.StandardMBeanIntrospector.invokeM2(StandardMBeanIntrospector.java:112)
at com.sun.jmx.mbeanserver.StandardMBeanIntrospector.invokeM2(StandardMBeanIntrospector.java:46)
at com.sun.jmx.mbeanserver.MBeanIntrospector.invokeM(MBeanIntrospector.java:237)
at com.sun.jmx.mbeanserver.PerInterface.getAttribute(PerInterface.java:83)
at com.sun.jmx.mbeanserver.MBeanSupport.getAttribute(MBeanSupport.java:206)
at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.getAttribute(DefaultMBeanServerInterceptor.java:647)
at com.sun.jmx.mbeanserver.JmxMBeanServer.getAttribute(JmxMBeanServer.java:678)
at javax.management.remote.rmi.RMIConnectionImpl.doOperation(RMIConnectionImpl.java:1445)
at javax.management.remote.rmi.RMIConnectionImpl.access$300(RMIConnectionImpl.java:76)
at javax.management.remote.rmi.RMIConnectionImpl$PrivilegedOperation.run(RMIConnectionImpl.java:1309)
at javax.management.remote.rmi.RMIConnectionImpl.doPrivilegedOperation(RMIConnectionImpl.java:1401)
at javax.management.remote.rmi.RMIConnectionImpl.getAttribute(RMIConnectionImpl.java:639)
at sun.reflect.GeneratedMethodAccessor5.invoke(Unknown Source)
at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:357)
at sun.rmi.transport.Transport$1.run(Transport.java:200)
at sun.rmi.transport.Transport$1.run(Transport.java:197)
at java.security.AccessController.doPrivileged(Native Method)
at sun.rmi.transport.Transport.serviceCall(Transport.java:196)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:573)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:834)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.lambda$run$0(TCPTransport.java:688)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:687)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:750)
Waiting for cassandra
  1. The installer will ask a number to questions during the initialization process. For most questions, a default value has been provided to simplify the effort for users new to OpenIAM. The section which requires input from the installer is market with the following message in the console: =============== CRITICAL SECTION ===============
Create the database schema accounts
OpenIAM has two schemas which are created by default: openiam and activiti. The openiam schema is the primary schema used by the platform and it stores a variety of information ranging from policies to user profile information and more. activiti is used to store information about workflows and their execution. The first set of questions raised by the installler are related to the creation of database user for every schema. Each question and its intent are listed below.
Set OpenIAM username for 'openiam' schema, default: idmuserThis is DB user name that will be used to manage the openiam OpenIAM schema. This is the primary schema in the solution data related to OpenIAM are stored. User name will be used by the OpenIAM application to communicate with database. The default value is idmuser.
Set OpenIAM password for 'openiam' schema, default: idmuserThis is the password that will be used for username which was provided in the previous step. The default value is: idmuser
Set OpenIAM username for 'activiti' schema. For MySQL it will be the same as for 'openiam', default: idmuserThis is DB user name that will be used to manage the activiti schema. User will be used by OpenIAM application to communicate with the database. Default value is idmuser.
Set OpenIAM password for 'activiti' schema. For MySQL it will be the same as for 'openiam', default: idmuserThis is the password that for the user associatd with the activiti schema. The default value is idmuser
OpenIAM uses RabbitMQ as the message broker and is the primary transport service used by OpenIAM application. Services are loosely coupled and they communicate with each other through the message broker. Cross service communicaiton is encrypted.
Memory cache
  • End user web session
  • Database object cache
E-mail notifications can be enabled for a broad range of operations in OpenIAM. Configuring a valid SMTP service is a pre-requisite to being able to send e-mail notifications. The next two questions ask the user to provide the SMTP credentials for the account which will be used to send e-mails from the application. These questions are optional at this time and you have the option to configure these later if needed.
At this point the installer has enough information to complete the installation of: Elasticseach, Redis, and RabbitMQ.
Use default value if this is new installation. If you are doing update, specify your current (before update) version here, like 4.1.11.0, default: 0.0.0.0If this install is an upgrade from an exisiting deployment, then the current version is important as it will determine which scripts need to be applied to upgrade the schema to the current version. If this is a new deployment, you can leave this blank
This is the name of the OpenIAM core database. If using MariaDB, this is most likely to be 'openiam', default: openiamThis question provides the option to choose the primary database schema. You should leave this blank and let it default to openiam. This value should only be changed if the scripts have been altered by the customer.
This is the name of the OpenIAM Activiti database. If using MariaDB, this is most likely 'activiti', default: activitiThis question provides the option to choose the database schema used by the workflow engine. You should leave this blank and let it default to activiti. This value should only be changed if the scripts have been altered by the customer.
Possible values: MySQL, Postgres, MSSQL, Oracle. Type of the database that you are going to use with OpenIAM. The RDBMS have to be already installed, default:mysqlSelect the type of database that you will be using as the OpenIAM product repository. You can leave this blank if you will be using either MariaDB or MySQL. If you are using either PostgreSQL, Oracle or Microsoft SQL server, enter one the following values based on your database type: postgres, oracle, mssql
Do you want to initialize OpenIAM Schema and Users? Select this if you are not created schema and users in RDBMS yet. Super user (root) password will required [y/n]If 'Y' then installer will create schemas in database and corresponded RDBMS users as well. For Oracle/MSSQL it will generate an SQL script that must be performed manually
Enter username for Super user (for mysql this is root), default: rootThe installer needs a super user account or equivalent which has the privileges to create new schema, users, tables, etc.
Enter password for super user (sa or root, depend on the db type), default:Enter the password for account provided in the last step
This is the hostname of where the openiam core database is., default: localhostEnter the host or DNS name of the server where the primary OpenIAM database will be deployed.
This is the port of where the openiam core database is. If using mariadb, this is most likely '3306', default: 3306Enter the port number used by the database server hosting the primary OpenIAM database
This is the hostname of where the OpenIAM activiti database is., default: localhostEnter the host or DNS name of the server where the workflow database will be deployed.
This is the port of where the openiam activiti database is. If using MariaDB, this is most likely '3306', default: 3306Enter the port number used by the database server hosting the workflow database
  • C:\Users\Asus>scp openiam-4.2.1.8.noarch.x86_64.rpm root@10...*:/usr/local/openiam/
  • The authenticity of host '10... (10...)' can't be established.
  • ECDSA key fingerprint is SHA256:5pP7vxJnDzbQ+Xg1VANjSBYL7HboHyM4RqFKW4qHkPU.
  • Are you sure you want to continue connecting (yes/no/[fingerprint])?`
  • Warning: Permanently added '10...*' (ECDSA) to the list of known hosts.
  • root@10...*'s password:
  • openiam-4.2.1.8.noarch.x86_64.rpm 23% 133MB 1.4MB/s 05:12 ETA`
OpenIAM Login page .
Application serversThis is the location of the OpenIAM service layer which the UI and rProxy need to communicate with. In most cases, the default value will be correct since each of these components will be deployed on the same host. However, this configuration provides the flexibility to have the UI and service layer on separate hosts.
Internet on box
Type 'n' and press 'Enter'.
To check current logs of any service you can use the following command. You can get the services using the following command: openiam-cli status command .
