Upgrading OpenIAM in RPM
OpenIAM platform constantly improves and develops to provide more functionality and convenience to users. Hence, new versions are released, requiring an upgrade. Several upgrading options are currently available, as discussed below.
| Type | Description |
| Database migration from version 3.X to 4.X | Provides steps for migrating a database from version 3.X to 4.X. |
| Upgrading infrastructure components | Gives guidelines on how to upgrade individual infrastructure components if required. |
| Upgrading from 4.2.1.5-4.2.1.8 versions to 4.2.1.10 | Describes how to upgrade from 4.2.1.x versions to the newer 4.2.1.10 version, considering the changes made. |
| Upgrading from 4.2.1.x versions to 4.2.1.11 | Describes how to upgrade from 4.2.1.x versions to the newer 4.2.1.11 version, considering the changes made. |
| Upgrading from 4.2.1.x versions to 4.2.1.12 | Describes how to upgrade from 4.2.1.x versions to the newer 4.2.1.12 version. |
| Upgrading from 4.2.1.x versions to 4.2.1.15 | Describes how to upgrade from 4.2.1.x versions to the newer 4.2.1.15 version. |
| Infrastructure upgrade in version 4.2.1.13 | Gives guidelines on how to upgrade individual infrastructure components in OpenIAM version 4.2.1.13. |
| Upgrading OpenIAM from versions 4.2.1.x to 4.2.2 | Describes how to upgrade from 4.2.1.x versions to 4.2.2 version. |
| Upgrading OpenIAM to 2026.2.1 version | This document contains the step-by-step procedure to upgrade OpenIAM when it is installed under the root (/) directory. |
