Installation without Internet access
This type of installation is suitable for both el8 RHEL / CentOS version. Also, during the installation you will be prompted to install MariaDB RDBMS. This is suitable for Demo and POC installations. If you have already had the database server, you should answer N for the prompt.
  1. Download the following files to a server that has internet access.
curl https://download.openiam.com/release/enterprise/2026.2.1/rpm/openiam-2026.2.1.noarch.x86_64.rpm --output openiam-2026.2.1.noarch.x86_64.rpm
curl https://download.openiam.com/release/enterprise/2026.2.1/dependencies/el8/openiamrepo.tar.gz --output openiamrepo.tar.gz
curl hhttps://download.openiam.com/release/enterprise/2026.2.1/binaries/frontend.tar.gz --output frontend.tar.gz
curl https://download.openiam.com/release/enterprise/2026.2.1/binaries/backend.tar.gz --output backend.tar.gz
curl https://download.openiam.com/release/enterprise/infra/httpd-libs.tar.gz --output httpd-libs.tar.gz
curl https://download.openiam.com/release/enterprise/2026.2.1/connectors/ldap-connector-rabbitmq.jar --output ldap-connector-rabbitmq.jar
curl https://download.openiam.com/release/enterprise/2026.2.1/dependencies/el9/openiamrepo.tar.gz --output openiamrepo.tar.gz
curl https://download.openiam.com/release/enterprise/2026.2.1/binaries/frontend.tar.gz --output frontend.tar.gz
  1. Create folder /usr/local/openiam on the server.
  2. Copy the following files that were downloaded earlier to /usr/local/openiam
    • backend.tar.gz;
    • frontend.tar.gz;
    • openiamrepo.tar.gz;
    • httpd-libs.tar.gz.
  3. Install from the RPM using the following command.
    sudo rpm -i openiam-2026.2.1.noarch.x86_64.rpm
    You will see output like the following.
openiam/
openiam/vault/
openiam/vault/openiam.cluster.policy.hcl
openiam/vault/openiam.policy.hcl
openiam/vault/secret.policy.hcl
openiam/vault/consul
openiam/vault/medusa
openiam/vault/vault
openiam/services/shutdown.sh
openiam/services/start_auth.sh
openiam/services/start_br.sh
openiam/services/start_device.sh
openiam/services/start_email.sh
openiam/services/start_esb.sh
openiam/services/start_groovy.sh
openiam/services/start_idm.sh
openiam/services/start_idp.sh
openiam/services/start_recon.sh
openiam/services/start_reportviewer.sh
openiam/services/start_sas.sh
openiam/services/start_selfservice.sh
openiam/services/start_selfservice_ext.sh
openiam/services/start_sync.sh
openiam/services/start_ui_static.sh
openiam/services/start_webconsole.sh
openiam/services/start_workflow.sh
openiam/env.conf
At this point the VM will reboot to initialize a variables that are needed for stack components such as OpenSearch. In case you don't want the VM to reboot for no, you can use shutdown -c command to cancel the server from rebooting.
  1. Execute the initialization step the openiam-cli. During this step the system will be installing and configuring the various components that make up OpenIAM. Please follow the instructions on the screen.
  2. The first question: Does this box have Internet access? [y/n]. Please enter N
  3. You will be asked about installing MariaDB as a default database. Would you like to install MariaDB RDBMS locally? Please answer Y if you would like to use local MariaDB RDBMS as a database server (good choice for quick and simple installation, like demo or POC or small size production platform (up to 500 active users)). Otherwise, please, answer N.
7.1. If you answer Y for MariaDB installation, installer will prepare all files and after will ask you some details:
  • Enter current password for root (enter for none): > Press: Enter button.
  • Set root password? [Y/n] > Press y button and after Enter.
  • New password: > Type password for the root user. You will need it later during the installation.
  • Re-enter new password: > Type the password for the root user as on the previous
  • Remove anonymous users? [Y/n] > Press y button and after press Enter.
  • Disallow root login remotely? [Y/n] > Press y button and after press Enter.
  • Remove test database and access to it? [Y/n] > Press y button and after press Enter.
  • Reload privilege tables now? [Y/n] > Press y button and after press Enter.
  1. The installation process will continue. The Cassandra backend as a Graph storage will be installed. Please, be patient as this process can take 4-5 minutes. If you see the ugly exception below, ignore it. This is a byproduct of Cassandra taking some time to start (this will be addressed in an upcoming release).
-- StackTrace --
at org.apache.cassandra.dht.Murmur3Partitioner.describeOwnership(Murmur3Partitioner.java:284)
at org.apache.cassandra.service.StorageService.getOwnershipWithPort(StorageService.java:5166)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at sun.reflect.misc.Trampoline.invoke(MethodUtil.java:72)
at sun.reflect.GeneratedMethodAccessor2.invoke(Unknown Source)
at sun.reflect.misc.MethodUtil.invoke(MethodUtil.java:276)
at com.sun.jmx.mbeanserver.StandardMBeanIntrospector.invokeM2(StandardMBeanIntrospector.java:112)
at com.sun.jmx.mbeanserver.StandardMBeanIntrospector.invokeM2(StandardMBeanIntrospector.java:46)
at com.sun.jmx.mbeanserver.MBeanIntrospector.invokeM(MBeanIntrospector.java:237)
at com.sun.jmx.mbeanserver.PerInterface.getAttribute(PerInterface.java:83)
at com.sun.jmx.mbeanserver.MBeanSupport.getAttribute(MBeanSupport.java:206)
at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.getAttribute(DefaultMBeanServerInterceptor.java:647)
at com.sun.jmx.mbeanserver.JmxMBeanServer.getAttribute(JmxMBeanServer.java:678)
at javax.management.remote.rmi.RMIConnectionImpl.doOperation(RMIConnectionImpl.java:1445)
at javax.management.remote.rmi.RMIConnectionImpl.access$300(RMIConnectionImpl.java:76)
at javax.management.remote.rmi.RMIConnectionImpl$PrivilegedOperation.run(RMIConnectionImpl.java:1309)
at javax.management.remote.rmi.RMIConnectionImpl.doPrivilegedOperation(RMIConnectionImpl.java:1401)
at javax.management.remote.rmi.RMIConnectionImpl.getAttribute(RMIConnectionImpl.java:639)
at sun.reflect.GeneratedMethodAccessor5.invoke(Unknown Source)
at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:357)
at sun.rmi.transport.Transport$1.run(Transport.java:200)
at sun.rmi.transport.Transport$1.run(Transport.java:197)
at java.security.AccessController.doPrivileged(Native Method)
at sun.rmi.transport.Transport.serviceCall(Transport.java:196)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:573)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:834)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.lambda$run$0(TCPTransport.java:688)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:687)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:750)
Waiting for cassandra
  1. The installer will ask a number to questions during the initialization process. For most questions, a default value has been provided to simplify the effort for users new to OpenIAM. The section which requires input from the installer is marked with the following message in the console: =============== CRITICAL SECTION ===============
Set OpenIAM username for schema openiam, default: idmuserThis is the DB username that will be used to manage the openiam OpenIAM schema. This is the primary schema in the solution data related to OpenIAM are stored. Users will be used by the OpenIAM application to communicate with the database. The default value is idmuser.
Set OpenIAM password for schema openiam, default: idmuserThis is the password that will be used for the username which was provided in the previous step. The default value is: idmuser.
Set OpenIAM username for schema activiti. For MySQL it will be the same as for openiam, default: activitiThis is the DB username that will be used to manage the activiti schema. Users will be used by OpenIAM application to communicate with the database. Default value is activiti.
Set OpenIAM password for schema activiti. For MySQL it will be the same as for openiam, default: activitiThis is the password for the user associated with the activiti schema. The default value is activiti.
Set OpenIAM username for schema groovy. For MySQL it will be the same as for openiam, default: groovyThis is the DB username that will be used to manage the groovy schema. Users will be used by OpenIAM application to communicate with the database. Default value is groovy.
Set OpenIAM password for the groovy schema. For MySQL it will be the same as for openiam, default: groovy.This is the password for the user associated with the groovy schema. The default value is groovy.
Database
Set OpenIAM username for schema 'groovy'., default: groovy
Set OpenIAM password for schema 'groovy'., default: groovy
Set OpenIAM password for REdis Sentinel., default: passwd00
User to Access OpenSearch. If you don't change it on the OS server side, leave it as elastic, default: elastic
Password for elastic to access OpenSearch, default: VlyXHUBDuhgv6BTKjTz7TumtBZL8Zbmu
Memory cache
  • End user web session.
  • Database object cache.
Initialize database schema
Use default value if this is new installation. If you are doing an update, specify your current (before update) version here, like 4.1.11.0, default: 0.0.0.0If this install is an upgrade from an existing deployment, then the current version is important as it will determine which scripts need to be applied to upgrade the schema to the current version. If this is a new deployment, you can leave this blank.
This is the name of the OpenIAM core database. If using MariaDB, this is most likely openiam, default: openiamThis question provides the option to choose the primary database schema. You should leave this blank and let it default to openiam. This value should only be changed if the scripts have been altered by the customer.
Possible values: MySQL, Postgres, MSSQL, Oracle. Type of the database that you are going to use with OpenIAM. The RDBMS have to be already installed, default: MySQLSelect the type of database that you will be using as the OpenIAM product repository. You can leave this blank if you will be using either MariaDB or MySQL. If you are using PostgreSQL, Oracle, or Microsoft SQL Server, enter one of the following values based on your database type: postgres, oracle, mssql.
This is the name of the OpenIAM Groovy database. If using MariaDB, this is most likely groovy, default: groovyThis question provides the option to choose the database schema used by OpenIAM. You should leave this blank and let it default to groovy. This value should only be changed if the scripts have been altered by the customer.
This is the hostname of where the Groovy database is, default: localhostEnter the host or DNS name of the server where the workflow database will be deployed.
This is the port of where the Groovy database is. If using MariaDB, this is most likely 3306, default: 3306Enter the port number used by the database server hosting the workflow database.
Do you want to initialize OpenIAM schema and users? Select this if you have not created schema and users in RDBMS yet. Super user (root) password will be required [y/n]If Y then the installer will create schemas in the database and corresponding RDBMS users as well. For Oracle/MSSQL it will generate an SQL script that must be performed manually.
Enter username for super user (for MySQL this is root), default: rootThe installer needs a super user account or equivalent which has the privileges to create new schemas, users, tables, etc.
Enter password for super user (sa or root, depending on the DB type), default:Enter the password for the account provided in the last step.
Do you use AWS RDS MariaDB? If yes, make sure the RDS DB instance has the parameter log_bin_trust_function_creators = 1 [y/n]Select N if AWS RDS MariaDB is not being used for this deployment.
This is the hostname of where the OpenIAM core database is, default: localhostEnter the host or DNS name of the server where the primary OpenIAM database will be deployed.
This is the hostname of where the Activiti database is, default: localhostEnter the host or DNS name of the server where the workflow database will be deployed.
This is the port of where the Activiti database is. If using MariaDB, this is most likely 3306, default: 3306Enter the port number used by the database server hosting the workflow database.
C:\Users\Asus>scp openiam-2026.2.1.noarch.x86_64.rpm root@10.*.*.*:/usr/local/openiam/
The authenticity of host '10.*.*.* (10.*.*.*)' can't be established.
ECDSA key fingerprint is SHA256:5pP7vxJnDzbQ+Xg1VANjSBYL7HboHyM4RqFKW4qHkPU.
Are you sure you want to continue connecting (yes/no/[fingerprint])?`
Warning: Permanently added '10.*.*.*' (ECDSA) to the list of known hosts.
root@10.*.*.*'s password:
* openiam-2026.2.1.noarch.x86_64.rpm 23% 133MB 1.4MB/s 05:12 ETA
In the last part of initiation script, nginx will be installed and nginx health check will wait for OpenIAM all services to come up.
Please use openiam-cli status monitor command for all services from other console.
OpenIAM Login page .
Content Provider NameYou can think of a content provider as an “alias” which represents a domain. This is described in more detail in the OpenIAM documentation. For this setup, please enter a value such as: Default CP
Grafana and Prometheus access
firewall-cmd --add-port=3000/tcp --add-port=9090/tcp --add-port=9100/tcp --permanent
firewall-cmd --reload
ss -tulnp | grep grafana
ss -tulnp | grep prometheus
http://<Ip of VM>:3000
Grafana dashboard
systemctl daemon-reexec
systemctl daemon-reload
systemctl restart Prometheus
Prometheus
Node exporter access
Internet on box
Type N and press Enter.
