> For the complete documentation index, see [llms.txt](https://docs.openiam.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.openiam.com/solution-architecture/solution-architecture.md).
# Solution Architecture and Design Guide
Choose how OpenIAM fits the estate you already have — authoritative sources, identity correlation, where authentication lives, how access is governed, and how OpenIAM coexists with a platform you are
**Applies to:** OpenIAM 2026.8.1
## What this is, and when you need it
This guide is for the decisions you make **before** anyone opens the Webconsole. OpenIAM supports more than one defensible answer to most architectural questions — where authentication lives, what links an identity across five directories, whether a request is governed here or in the platform you already run — and choosing badly is expensive to undo once identities exist and applications are integrated. Every page here names a decision, gives the trade-offs, states a recommendation, and hands off to the guide that tells you how to implement it.
It assumes you know identity and access management. It does not reteach LDAP, SAML or SoD theory, and it does not describe OpenIAM's object model — the Administration Guide does that, and this guide links to it rather than restating it.
## Which guide owns your question
| I want to…                                         | Guide        |
| See OpenIAM working, quickly, on a lab             | [Getting started](https://docs.openiam.com/getting-started-guide/getting-started.md)                                |
| Choose between options before I configure anything | **This guide**        |
| Configure something in the Webconsole              | [Administration Guide](https://docs.openiam.com/administration-guide/admin.md)                                      |
| Stand up, size, upgrade or recover a deployment    | [Installation Guide](https://docs.openiam.com/installation/installation.md)                                         |
| Extend OpenIAM, or call it from my own code        | [Developer Guide](https://docs.openiam.com/developer-guide/developerguide.md)                                       |
| Use the SelfService portal                         | [SelfService user guide](https://docs.openiam.com/end-user-guide-for-selfservice/end-user-guide-for-selfservice.md) |
## Where a decision hands off to a build
Several pages here stop at a decision and hand the build to the [Installation Guide](https://docs.openiam.com/installation/installation.md) — the port inventory, inter-node firewall rules, tuning values, the upgrade tooling. Follow the link at the foot of the page; the decision is complete here and the procedure is there.
{% hint style="info" %}
**Sizing is the one hand-off that is still partly open.** [Sizing](https://docs.openiam.com/solution-architecture/deployment/sizing.md) gives the bands and the inputs, and the Installation Guide gives the shipped defaults in [Configuration tuning reference](https://docs.openiam.com/installation/tuning.md) — but per-service figures for a specific population and batch profile come from OpenIAM rather than from either guide.
{% endhint %}
## How to use it
Read Part 1 once — it explains what OpenIAM is made of and why, which is the question most often asked and least often answered. After that, go to the decision in front of you. The parts are ordered the way a programme runs: identity first, then authentication and access, then governance, then coexistence and migration. That order is itself a recommendation, and Part 8 explains why it matters.
# Agent Instructions
This documentation is published with GitBook. GitBook is the documentation platform designed so that both humans and AI agents can read, navigate, and reason over technical content effectively. Learn more at gitbook.com.
## Querying This Documentation
If you need additional information that is not directly available in this page, you can query the documentation by asking a question.
GET https://docs.openiam.com/solution-architecture/solution-architecture.md?ask=<question>&goal=<user_goal>
Use this mechanism when the answer is not explicitly present in the current page, you need clarification or additional context, or you want to retrieve related documentation sections.
