Your AI assistant conversations
Use the AI assistant in SelfService — type and send a question, ask about your access, roles and colleagues, read its cards and tables, request access for yourself, pick a suggested follow-up question
Applies to: OpenIAM 2026.11.2
The AI Assistant in SelfService answers questions about your access, your requests and your approvals. It keeps every conversation you have with it, so you can come back to one later and carry on where you left off.
Use this page to find your way around the assistant, to return to something you asked it earlier, or to start again with a clean conversation.
Opening the assistant
Click Assistant at the top of the SelfService menu, above the other menu groups. It has a sparkle icon and a Beta label.
Your organization decides who gets the assistant. If you do not see Assistant in your menu, it has not been turned on for you, or it is not available at the moment.
While the assistant is out of service, SelfService hides the Assistant menu entry. You do not need to reload the page. The entry comes back by itself, usually within a minute of the assistant working again. If the assistant could not be reached at all, it comes back the next time you open a page once it works again.
A conversation you already have open stays open, and so does your list of conversations. A question you send while the assistant is out of service shows a box that says what went wrong, as described in When the assistant cannot answer. Click Retry once the assistant is back.
If you open the assistant from a bookmark or a link while it is not available, you see The assistant is unavailable and the reason:
The assistant has not been enabled for your organisation. Contact your administrator.— you do not have the assistant. Ask your IT administrator if you need it.The assistant is temporarily degraded. We're working on it, please try again later.— the assistant is having a problem. Try again later.
If the assistant is taken away while you use it
Your organization can turn the assistant off, or take it away from you, while you have it open. This does not happen at once: depending on how your administrator made the change, it takes from under a minute to about an hour. After that, nothing you send reaches the assistant any more. The next time you send a question, or open, rename, pin, archive or delete a conversation, the assistant shows The assistant is unavailable and the reason, as above. From then on, the Assistant menu entry stays hidden for the rest of your visit. When you reload the page, SelfService checks again. You cannot open or change your earlier conversations until you have the assistant again.
If the assistant cannot check whether you have it, it does not answer and shows an error instead. Click Retry to ask again a moment later.
Before your first question
The first time you send a question, a Before you start box opens. It explains:
that the assistant only sees what you are allowed to see in OpenIAM, such as your own details, approvals, requests and team;
which model the assistant uses, and that your questions, and the information needed to answer them, are sent to the company that provides the model, outside your organization's network;
that the assistant never changes anything on its own, and always asks you to confirm an action first;
how long your conversations are kept.
Click Got it. The question you typed is then sent for you, so you do not need to type it again. The box does not appear again in that browser.
To read it again later, click More options (the three dots at the top right of the assistant), then Disclaimer & privacy. You can also click Disclaimer under the message box. If you use another browser or another computer, or clear your browser's data, the box appears once more before your first question there.
Finding your way around the assistant
The top of the assistant shows its title, Assistant, with a Beta label beside it. The label means the assistant is new: check what it tells you before you act on it.
Each of your questions appears in a bubble on the right, and each answer appears beside the assistant's icon. Point at one of your questions to see the time you sent it.
Under the message box, a line reads The assistant can make mistakes — check important information. Actions always ask for your confirmation. Click Disclaimer beside it to read what the assistant sees and where your data goes.
Before you ask anything
An empty conversation greets you by your first name, for example Hi Anna, how can I help?, and says in one sentence what the assistant can help with. Under it are four questions you can start from: Give me an overview, What approvals are waiting on me?, Request access to an application and Show my access review campaigns. Click one to send it.
Typing your question
Type your question in the message box at the bottom of the assistant.
Press Enter to send it. Press Shift+Enter to start a new line instead.
If you type with an input method, for example for Japanese or Chinese, the Enter that picks a word only picks the word. It does not send your question.
The box starts two lines high and grows as you type, up to about two fifths of the screen. After that, it scrolls.
A message has a maximum length, set by your organization. When you reach 80% of it, a counter such as
3200 / 4000appears beside the send button. It turns red at the maximum, and the box takes no more text. If you paste a longer text, it is cut at the maximum.The send button, an arrow, is greyed out while the box is empty. While the assistant writes an answer, it becomes Stop: click it to stop the answer.
On a phone, the message box stays at the bottom of the screen, above the keyboard.
Where your data goes
Click More options (the three dots at the top right of the assistant) to see the model the assistant runs on, and beneath it the line Cloud model · data is sent outside your network. It means that your questions, and the information the assistant looks up to answer them, are sent to a service outside your organization.
If no such line appears, the assistant has not said where it sends your data. Ask your IT administrator.
Seeing how the assistant reached an answer
Before some answers, the assistant shows the reasoning it went through, folded away. Click it to read it.
To have that reasoning open every time, click More options, then turn on Always show reasoning. The choice is kept for this browser.
Seeing what the assistant can do
To see what you can ask the assistant, and what it will not do, open What can the assistant do? in either of two ways:
On an empty conversation, click the What can the assistant do? link under the suggested questions.
Click More options (the three dots at the top right of the assistant), then What can the assistant do?.
A panel opens on the right and lists:
Answer — what the assistant can tell you about: your approvals, requests and access; the roles, groups and applications you have; access review campaigns; your manager and the people who report to you; your sessions, devices and IT policy status; and how-to questions answered from the product documentation.
Act (always with your confirmation) — what it can do for you once you confirm: approve or reject an approval task, and request access for yourself.
Open the right screen — where it sends you instead of acting in the conversation: the pages for your password, multi-factor authentication (MFA) and security keys, and any other page for something it cannot do in the conversation.
Limits — what it does not do: approve many items at once, change a password, MFA setting, security key or device, accept attachments or voice input, or see anything beyond what you are allowed to see.
The line about how-to questions appears only when your organization lets the assistant search the product documentation.
To close the panel, click Close (the cross at its top right), press Esc, or click anywhere outside it. On a phone, it fills the whole screen.
Until your organization's translation is available, the text in this panel is in English when you use SelfService in another language.
Using the assistant with a keyboard or screen reader
You can use the assistant with the keyboard alone, and with a screen reader.
What your screen reader tells you
Your screen reader names the conversation Assistant. It does not read an answer out word by word while the assistant is still writing it. Instead it tells you when something has happened:
When an answer is complete, you hear
The assistant finished answering.once. Move into the conversation to read the answer.After you approve, reject or request something from a card, you hear the short record that replaces the card, for example
Approved · 14:02. #1234 · Salesforce · Anna.When the assistant cannot answer, you hear the title of the problem, for example
The answer took too long. The problems are listed under When the assistant cannot answer.After you copy something from an answer, you hear
Copied.
Where the cursor goes
Cards, suggested questions, sets of questions and notices come and go as the conversation moves on. If the cursor is on one of them when it disappears, the cursor moves to the message just above it, or to the conversation itself. It never jumps back to the top of the page, so you do not lose your place.
Buttons that show only an icon
Buttons that show only an icon display their name when you point at them or move to them with Tab. These include More options, Scroll to the latest message, the send and stop button under the message box, and the buttons in your list of conversations, such as New chat. A screen reader reads the same name.
The buttons on code and tables in an answer, such as Copy code, Copy table and Download table, appear in the language you use SelfService in.
Less motion
If you have turned on the setting that reduces motion on your device, for example Reduce motion on a Mac or iPhone, or turned off Animation effects in Windows, the assistant follows it:
The shimmering line that says what the assistant is doing, such as
Thinking…, shows as plain text.The conversation jumps to the latest message instead of scrolling to it smoothly.
Panels, menus and other parts of the assistant appear and disappear at once, without animation.
The Segregation of Duties (SoD) warning on a confirmation card is also shown with enough contrast to read easily in the light theme.
Following what the assistant is doing
While the assistant works on your question, a line above its answer says what it is doing, in plain words — for example Thinking…, Looking up your approvals…, Checking your access, Searching organizations or Finding the right screen…. If it takes longer than a few seconds, the line adds Still working….
When the answer is ready, the line turns into a short summary with a check mark, for example Looked up your approvals · Found the right screen. Click the summary to see every step, in order.
A step that went wrong says so, for example Could not load your approvals, and the summary shows a warning instead of a check mark. When an administrator has switched off the assistant's access to your OpenIAM data, the step says that instead. A step that never finished, because you stopped the answer or it was cut off, shows Stopped in that list.
An answer that ended with a button to another SelfService page counts as finished. When you reload the page, or come back after following that button, the answer still shows its steps as done, and you can still regenerate it. Only an answer you stopped yourself shows Stopped.
Some of these lines may still appear in English when you use SelfService in another language, until your organization's translation is available.
Asking about your access, roles and colleagues
You can ask the assistant about the access you have, about the roles, groups and resources in OpenIAM, and about the people you work with.
"Do I have the Finance role?" The answer card is headed
You have this accessorYou do not have this access. When you do not have it, the assistant also says whether you can request it, and if you can, the card offers Request it. Click it to request the access from the conversation; see Requesting access for yourself."What is the Finance role for?" The assistant shows a card with the role's name, type, status and description. You can ask the same about a group or a resource.
"Find groups with Finance in the name." You can search roles, groups, resources and organizations. Several results appear as a table; a single result appears as a card with its details.
"Who is my manager?" and "Show me Alex's details." You can look up yourself, the people who report directly to you, and your own managers. When you search for people by name, the assistant finds only you and the people who report directly to you. It cannot find anybody else, such as a colleague, your manager's manager or a person who reports to somebody on your team, and it tells you so.
"What access does Sam Patel have?" When you ask about the roles and groups of somebody who reports to you, the table's title names that person, for example
Access of Sam Patel (your direct report), so you can always see whose access you are looking at. If the name in your question is close to, but not, the name of somebody on your team, such as Sam Patil when your report is Sam Patel, the assistant usually asks whether you meant Sam Patel. Answer yes, or ask again with the name as it appears on your My Team page. Whatever name you typed, a table of somebody's access is always titled with that person's real name.
When you ask about somebody you are not allowed to see, the assistant tells you so in plain words instead of showing an error. If that person reports to you, it offers a button to your My Team page instead.
The assistant treats names, descriptions and other text stored in OpenIAM as information only. The same goes for the documentation pages it reads to answer a how-to question. If such text contains something that reads like an instruction, the assistant does not follow it.
Reading the assistant's answers
Many answers come as a card or a table rather than only as text.
Figures. A question such as "How are my reviews going?" shows a row of tiles, each with one figure. Click a tile to open the page it comes from; the certification tiles open My Campaigns. Counts that are past due show in red, and counts that are due soon show in amber. If one figure could not be read, its tile shows
Could not load, and the other tiles still show theirs.Certification campaigns. Each campaign shows as a card with its due date and the number of items you still have to review, for example
12 items left, a progress bar such as8 of 20 reviewed, and an Open campaign button. When the assistant has room, the cards sit two to a row.Your profile. "Show my profile" shows a card with your initials, your name and status, your job title and organization, and your email address. Click Open profile to go to your profile page.
Pictures and diagrams. The assistant never shows pictures. Where an answer, or its reasoning, contains one, you see only the picture's short description, and nothing is loaded from the internet. A diagram shows as the plain text it is written in.
Status labels. Statuses such as
Pending,Approved,Rejected,OverdueandActiveshow as colored labels. A status the assistant does not recognize shows as plain text.Links. A link to a page in SelfService shows as a button that opens that page, if you can use it. A link to the OpenIAM documentation opens in a new tab. Any other link, for example to another website, shows as plain text that you cannot click. This keeps an answer from sending you somewhere unexpected. If you need that page, open it from the menu.
Tables. The first column shows an icon for the kind of item — a role or other access, a group, an application, a request or a task. A table of the people who report to you shows each person's initials. The row under your pointer is shaded, so you can follow it across.
While the assistant is still fetching the information, four grey lines show where the table or cards will appear.
Seeing the details of a table row
When a table has more than you can read at a glance, such as a table of the requests waiting for your approval, you can open one row's details beside the conversation. This works when your browser window is wide: at least 1280 pixels, as on most computers with the window open fully. In a narrower window, the names in a table are plain text and there are no details to open.
Click the name in a row. With the keyboard, press Tab until you reach the name, then press Enter.
The row is tinted, and a Details panel opens on the right of the conversation.
Read the row's information in the panel. Each value sits under the same name as its column in the table. A status shows as the same colored label as in the table, and dates are written out in full.
To see another row, click its name. The panel switches to that row.
The panel shows only what is already in the answer. It does not look anything up again, so it is as up to date as the answer itself; to see the latest information, ask the assistant again.
The panel closes when you:
click Close details at the top of the panel
press Esc
click New chat
open another conversation
make the browser window narrower
To open it again, click a name in the table.
Picking a follow-up question
When the assistant has finished an answer, up to three suggested follow-up questions appear under it. While they are being prepared, pale placeholders pulse in their place. Click a suggestion to send it as your next question.
Suggestions only appear under the latest answer, and only when that answer finished normally — not under an answer you stopped or one that failed. They also do not appear under an answer that ends on the record of an approval or rejection card, described in After you decide. They disappear as soon as you send a new question, and they come back on the latest answer when you reopen the conversation. The questions on the empty assistant, before you ask anything, look the same and work the same way.
Rating an answer or reporting a problem
Every finished answer has a row of small buttons under it, beside Copy and Regenerate. On a computer, the row appears when you point at the answer or move to it with the Tab key; on a phone it is always shown. Three of these buttons let you say how good the answer was:
Good answer (thumbs up) — the answer was right and useful.
Bad answer (thumbs down) — the answer was wrong or did not help.
Report a problem (flag) — something in the answer needs a closer look, and you want to say what.
The buttons appear only once the assistant has finished the answer. While it is still writing, or while a card in the answer is waiting for you to confirm something, they are not shown yet.
Rate an answer
Click Good answer or Bad answer. The button you chose stays highlighted, and Thanks for the feedback. appears.
To change your mind, click the other button. To take your rating back, click the highlighted button again; it is no longer highlighted, and the answer has no rating.
If you see Your feedback could not be saved. Please try again., your rating was not kept, and the buttons go back to how they were. Click the button again a little later.
Report a problem
Click Report a problem under the answer. The Report a problem dialog opens.
Optionally, describe what was wrong in What went wrong? (optional). You can type up to 1,000 characters; the count under the box shows how many you have used.
Click Send report. Click Cancel instead to close the dialog without reporting anything.
When the report is sent, Thanks — the problem was reported. appears, and the button now reads Problem reported. Report it again. You can report the same answer again later, for example to add something. Each new report replaces the comment you sent before.
If you see The problem could not be reported. Please try again., the dialog stays open with your comment still in it. Click Send report again a little later.
Your comment is kept with this conversation. Do not put passwords or other secrets in it.
What happens to your feedback
Your ratings and reports are saved with the conversation. They are still shown when you reload the page or come back to the conversation later, and you can rate answers in earlier conversations too. When the conversation is deleted, by you or automatically after the time your organization keeps conversations, your feedback is deleted with it.
Your organization can see which answers were rated and reported, to find out where the assistant needs to improve.
An answer that could not be saved to your conversation has no rating buttons; see When an answer was not saved.
How a conversation gets its name
A new conversation is first named after the first words of your question. Once the first answer has finished, the assistant gives it a short title of its own, in the language you use SelfService in. If that first answer ends on the record of an approval or rejection card, the title comes with the next answer instead. If you renamed the conversation yourself in the meantime, your name is kept.
Getting an overview
Ask the assistant for an overview, for example Give me an overview or Summarize what I have and what is waiting on me. It answers with one Your overview card that shows how many items wait for your approval, your review campaigns, the roles and groups you hold, and the applications you can open. Click a figure to open its page. While the assistant works, its activity line reads Putting your overview together.
If one figure cannot be found, that tile shows Could not load and the others still show. Ask again later for the missing figure, or open its page.
Asking about the page you are on
The assistant knows which SelfService page you opened it from, and the language you use SelfService in. If you are looking at a task, a request, a certification campaign or a team member, it also knows which one. So on a request's page you can ask "What is the status of this?" without saying which request you mean.
It only knows which page and which item. It does not read what is on your screen, and the page is not kept with your conversation.
Asking about your sign-ins, devices, accounts and IT policies
You can also ask the assistant about where you are signed in, the devices you registered, your accounts and the IT policies you have to accept. It always answers about you, never about somebody else.
"Where am I logged in?" The assistant shows a
Where you are signed intable with the application, the IP address and the time you signed in for each of your active sessions. A button takes you to the My Sessions page."Which devices do I have?" The assistant shows a
Your registered devicestable with each device's manufacturer, model and platform. A button takes you to the My Devices page."What accounts do I have?" The assistant shows a
Your accountstable with each login you have on the systems your organization manages: the login, the system, whether the account is enabled, disabled or locked, and when its password expires. You can also ask "When does my password expire?". The assistant never shows a password or any other secret."Which policies do I still need to accept?" The assistant shows a
Your IT policiestable. It lists first the IT policies you still have to accept for each application, how often you have to accept them again, and how long they have been waiting. Below them is the history of the policies you accepted or revoked, with dates. A button takes you to the IT Policy page, where you accept a policy yourself.
Statuses such as Accepted, Revoked, Enabled, Disabled and Locked show as colored labels. While the assistant looks these up, its activity line says so, for example Looking up where you are signed in or Checking your IT policies, and afterwards Checked your IT policies.
Some of these labels may still appear in English when you use SelfService in another language, until your organization's translation is available.
Your list of conversations
On a wide screen, such as a computer, the assistant's page shows a Conversations panel on the left with all your conversations, and the conversation in the middle.
On a narrower screen, such as a tablet or a phone, the panel is hidden. Click History at the top left of the assistant to open it. It slides in from the left, and fills the whole screen on a phone. It closes when you open a conversation or start a new one. To close it without choosing, click Hide conversations, press Esc, or click beside it.
The list is grouped under Pinned, Today, Yesterday, Last 7 days and Older, by when each conversation last had a message. Pinned conversations always come first. The conversation you have open is highlighted. A conversation that has no title yet reads New conversation; when the assistant gives it a title during an answer, the title fades into the list. If your conversations do not all fit, click Show more conversations at the bottom of the list.
Click a conversation to open it.
Finding a conversation
Type a word into Search conversations at the top of the panel. The list narrows to the conversations whose title or first message contains that word. If nothing matches, the list reads No conversations found.
Renaming, pinning, archiving and deleting a conversation
Point at a conversation, then click Conversation options (the three dots beside it). The menu offers:
Rename — the title becomes a box you can type in. Press Enter to keep the new name, or Esc to leave the old one.
Pin — moves the conversation to
Pinned, at the top of the list. On a pinned conversation, the same item reads Unpin.Archive — removes the conversation from your list without deleting it.
Delete — asks
Delete this conversation?and names the conversation. Click Delete to remove it for good, or Cancel to keep it. If you delete the conversation you have open, the assistant starts a new, empty one.
Deleting all your conversations
Click History options (the three dots at the top of the Conversations panel).
Click Delete all conversations.
The assistant asks Delete all conversations?. Type DELETE in the box. The Delete all conversations button in the dialog stays greyed out until you have typed the word exactly.
Click Delete all conversations in the dialog. Every conversation you have is removed for good, and this cannot be undone. Click Cancel instead to keep them.
When a change is refused
If the assistant cannot rename, pin, archive or delete a conversation, a notice above the list says why. Click Dismiss to close it.
This conversation is answering in another tab. Try again when it has finished.— wait for the answer in the other tab to end, then try again.This conversation no longer exists. It may have been deleted in another tab.— the conversation is already gone.The change could not be saved. Try again.— try again in a moment.
If the panel shows Your conversations could not be loaded right now., reload the page.
Hiding the panel
On a wide screen, click Hide conversations, the first button at the top left of the assistant, to hide the panel and give the conversation more room. Click the same button, now Show conversations, to bring it back. The browser remembers your choice the next time you open the assistant.
Coming back to a conversation
The quickest way back to a conversation is to click it in the Conversations panel. You can also use its address: as soon as the assistant gives its first answer in a new conversation, the address in your browser changes to one that belongs to that conversation. Opening that address later brings the whole conversation back.
While the conversation is open, bookmark the page, or copy its address.
When you want to return to it, open the bookmark or paste the address into your browser.
Type your next question at the bottom and carry on.
The address only opens the conversation for you. If you send it to a colleague, they see that the conversation could not be found, because nobody else can read your conversations.
If you leave the assistant and come back to it in the same browser tab, it reopens the conversation you last had open in that tab. A new tab, or a tab you closed and opened again, starts with an empty conversation.
The same conversation in two tabs
If you have the same conversation open in two browser tabs, the assistant answers in only one of them at a time. While one tab is answering, the other shows This conversation is answering in another tab. above the message box, and its message box, Send and Regenerate are greyed out.
When the answer ends, the waiting tab shows the new messages by itself, without a reload, and you can type in it again. If the answering tab was closed or stopped working in the middle of an answer, the other tab becomes usable again within about a minute.
Tabs that show different conversations do not affect each other.
Starting a new conversation
Click New chat at the top of the assistant, beside its title, or click + at the top of the Conversations panel. On a phone, New chat shows only its icon. The assistant opens an empty conversation, and the one you left stays saved; you can still return to it from the list or from its address.
Reading earlier messages
A long conversation opens on its latest messages. Scroll up to load the ones before them, a page at a time. You can also click Show earlier messages at the top of the conversation.
If you see Earlier messages could not be loaded., click Show earlier messages again.
If you start typing a question and then switch to another conversation, your unsent text is still there when you come back, as long as you do not reload the page.
Cards from an earlier visit
Some answers come with buttons, for example a card asking you to confirm that you approve a request, or a short set of questions the assistant needs answered. Those buttons only work while the card is new and is the last thing in the conversation.
When you reopen a conversation, or when the conversation has moved on past a card, the card shows No longer active — ask again instead of its buttons. Nothing was approved, rejected or sent from it. To do what the card offered, ask the assistant again, and it gives you a fresh card.
The buttons on a set of questions from the assistant read Submit and Cancel, in the language you use SelfService in.
Approving or rejecting a request
When a request waits for your approval, you can decide it from the assistant. Ask, for example, "Approve request #1234" or "Reject the Finance-Read request". The assistant never decides a request on its own. It shows a card for you to check first, and nothing happens until you press a button on that card.
What the card shows
Everything on the card comes from the request itself, not from the assistant's own words:
What will happen. A title, such as
Approve access request, and one sentence saying what your decision does, for exampleAnna Kovac will get Finance-Read in SAP until 31 Dec 2026.The details. Requester, Item, Beneficiary, Justification and Duration. A request with no end date shows
No end date.Validation. Either
No policy conflicts found., or aSoD conflictwarning that names the Segregation of Duties (SoD) rule the request breaks, for example two kinds of access that one person should not hold together. When the request was not checked, the card saysPolicy conflicts were not checked for this request.Open approval task. A button, for example Open approval task #1234, that opens the request's task page, where you can see everything about it.
While the card reads the request, it shows Loading the request…. If it shows Could not load this request., click Try again.
Approve the request
Read the sentence and the details on the card.
Click Approve request followed by the request's number, for example Approve request #1234.
Reject the request
Click Reject.
In Reason for rejection, type why you are rejecting it. The requester will see this comment, and the reason is required.
Click Reject request followed by the request's number, for example Reject request #1234.
If you asked the assistant to reject the request, the card opens with Reason for rejection already showing. If you click Reject request with no reason, the card shows Please add a reason. and sends nothing.
Change your mind
Click Cancel, or press Escape while the card is selected. Nothing is approved or rejected.
While Reason for rejection is showing, Cancel only takes you back to the first set of buttons, so you can approve instead. Press Escape to cancel the whole card.
Using the keyboard
When the card appears, the card itself is selected, never one of its buttons. So if you are still typing and press Enter, nothing is approved or rejected by accident. Press Tab to move to the buttons, then Enter to press one.
After you decide
The card is replaced by a short record of what you did, for example Approved · 14:02, Rejected · 14:02 or Cancelled · 14:02. Below it are the request's number, the item and the beneficiary, the reason you gave for a rejection, and Request status: followed by the request's status as it is now. Click Open to go to the request's task page. A cancelled card has no Open button.
The record is the assistant's whole statement of the outcome: the answer ends there, and the assistant does not add a sentence repeating what the record says.
After you decide, the cursor goes back to the message box, so you can type your next question straight away.
If your decision could not be saved, the record reads Could not complete, followed by The server returned: and the reasons OpenIAM gave. Nothing changed. Open the task page from the record to decide the request there, or ask your help desk if the reason is not clear. If OpenIAM gave no reason, the assistant adds a short explanation under the record.
When the request cannot be decided here
Some requests cannot be decided from the assistant. The card then says why, instead of showing the approve and reject buttons, and offers Open approval task to decide it on its task page:
This request is no longer waiting for your decision.— somebody already decided it, or it was closed.Claim this request on its task page before you decide it.— the request has to be claimed on its task page first; once you have claimed it there, you can decide it.This request cannot be decided here. Open its task page instead.— for any other reason.
From a table of your approvals
When you ask what is waiting for your approval, the assistant shows a table of those requests. Each row has Approve and Reject buttons. They do not decide the request straight away: they ask the assistant for you, for example "Approve request #1234", and the assistant then shows the card described above for you to check. The buttons only work in the latest answer.
You can ask the assistant for access you do not have yet. It fills in the same request you would make on the request screen, and it never sends one without your say-so: nothing is requested until you press Submit request.
Finding what you can request
Ask, for example, "What can I request for Salesforce?" or "What can I request?". The assistant shows a What you can request table of the applications you can request, with their Name and Category. Each row has a Request button, which asks the assistant for you, for example "Request Salesforce for myself".
The table can also show three more columns, when your organization has recorded these details for the applications:
Type — what kind of application it is.
Risk — how sensitive the access is, as a colored
High,MediumorLowlabel.Owner — the person or group responsible for the application.
A column appears only when at least one application in the table has a value for it. An application with no value leaves its cell empty.
Request access
Ask for the access, for example "Request Salesforce for myself". You can also click Request on a row of the table, or Request it on an answer that says you do not have some access.
A form headed Request and the item's name appears in the conversation. If the application offers more than one kind of access, choose the one you need under Which access do you need?.
In Justification, type why you need this access. The justification is required.
Under Duration (optional), choose how long you need the access. The form only offers the lengths this access allows: No end date, 30 days and 90 days, or, when the access has a time limit, the lengths within it and a Maximum option. When the access cannot be time-limited, the form has no duration.
Click Continue. The form turns into a summary of what you entered, marked Details sent.
Wait while the assistant shows Checking policy rules. It then reads No conflicts, or the number of conflicts it found, for example 1 conflict found.
Read the confirmation card, then click Submit request.
What the confirmation card shows
What will happen. The title
Request access, and one sentence that says who will approve the request first, such asA request for Sales-User in Salesforce will be sent to Jana Novak for approval.Instead of a person, the approver can readmembers of the Finance Approvers role,members of the Finance Approvers grouporyour manager. When several people share that first approval, the sentence adds how many, for exampleJana Novak or one of 2 other approvers. When OpenIAM cannot tell who approves, the sentence readsA request for Sales-User in Salesforce will be sent for approval.The details. Item, Beneficiary (always
You), Justification and Duration.Validation. The same notice about Segregation of Duties (SoD) conflicts that the request screen shows. When the access conflicts with a policy but can still be requested, tick the box saying you understand the conflict. Submit request stays greyed out until you do.
Open the request screen. A button that takes you to the request screen, if you would rather make the request there.
To change your mind, click Cancel, or press Escape while the card is selected. Nothing is requested.
After you submit
The card is replaced by a short record of what happened:
The request's number and the time, for example
Request #4711 submitted · 14:02, with the item and the duration below. Click Open request to follow the request. Your approvers take it from there, as for any other request. When OpenIAM does not return the request's number, the record readsRequest submittedand offers Open my requests instead.Could not complete, followed byThe server returned:and the reasons OpenIAM gave. No request was sent. Click Open the request screen to request the access there, or ask your help desk if the reason is not clear. The request screen opens with that application already selected and its list of access open, so you can pick the access and try again. If the application cannot be opened for you there, the request screen opens as usual with the noteThis item cannot be opened here. Click Dismiss to close the note, then find the access in the catalog.Cancelledand the time, withNo changes were made.
If the record adds The item is still in your request cart. Remove it there so it is not requested again., open the request screen and remove the item from your cart.
When the item cannot be requested here
Some access can only be requested on the request screen. Instead of a form, the assistant then says why and offers Open the request screen. For example:
You already have this access.This access is already in your request cart. Finish the request on the request screen.This access needs choices that only the request screen collects.This item can only be requested on the request screen.This item is not in your request catalog. Look for it on the request screen.This item offers more access than fits here. Choose it on the request screen.
Requesting access for somebody else
The assistant only requests access for you. If you ask it to request access for somebody else, for example "Request Salesforce for Anna", it creates nothing. It offers a Request for others button instead.
Nothing opens until you click the button. When the assistant knows who you mean, for example one of your direct reports, the button opens the request screen with that person's name next to "Requesting for", so all that is left is to choose what they need. When it does not, the button opens Create Request; select Change there to pick the person. See Requesting for other people.
You see the button only if you are allowed to request for other people. Otherwise the assistant shows This screen is not available to you.
Answering the assistant's questions
Sometimes the assistant needs more from you before it can help, for example which of two roles you mean. It then shows a short set of questions with choices to pick or a box to type in. The set is selected when it appears, never one of its buttons, so a stray Enter does not send it. Press Tab to move to the first choice.
If you click Submit with a question unanswered, nothing is sent: that question shows Answer this question to continue., and the cursor moves to it.
To answer with the keyboard:
Each list of choices is a single Tab stop. Press Tab to move into the list, and Tab again to move on to the next question.
Use the arrow keys to move between the choices in a list. Moving to a choice does not pick it.
Press Space or Enter to pick the choice you are on.
Press Esc to go back to the message box without sending. The answers you have already given stay in the set, so you can come back and finish it.
One decision at a time
The assistant never approves, rejects or requests anything on its own: it always shows a card for you to confirm first. It offers one such card per answer. While a card waits for you, and after you have confirmed or cancelled it, the assistant does not offer another card in the same answer.
So if you want to approve two requests, confirm the first card, then ask the assistant about the second one in a new message. If you ask it to approve several at once, it explains that each approval is confirmed on its own card instead. It only decides tasks that are in your approvals, so it does not act on a task number you type that is not one of them.
If you cancel an approval or rejection card, its record reads Cancelled and the answer ends there. Nothing is approved or rejected.
If you paste a one-time code into the conversation for an approval, the assistant refuses it. It offers the page where you set up your authenticator only when you ask to set up or reset a sign-in method.
The assistant also only ever looks up and acts on your own requests, approvals and access. You cannot ask it to act as somebody else. If you manage a team, you can still ask about the roles and groups of the people who report to you. When you ask about anybody else, for example a colleague's requests, your manager's roles or a user ID you type, the assistant tells you that it can only show your own information and your team's roles and groups. It does not show your own information in its place, and it does not offer you a button to one of your own pages instead.
Sending a message while a card is open
You can type a new message while a card still waits for you, or while a decision you confirmed is still being saved. What happens to the card depends on whether you had already confirmed it.
You had not confirmed the card yet. Sending a new message cancels the card. It shows
Cancelledand the time, and nothing is approved, rejected or requested. The assistant then answers your new message.You had already confirmed the card. Your approval, rejection or access request is not cancelled. Your new message waits until it has been saved, and the card then shows what really happened: the request approved or rejected, the access request you submitted with its number, or
Could not completewith the reasons OpenIAM gave. For an access request, the assistant first tells you that outcome, sometimes in a short extra answer; for an approval or rejection, the record on the card is the outcome. The assistant then answers your new message.
While your first message waits, a second one is not sent. Its text goes back into the message box, so you can send it once the assistant has answered. The same happens if the assistant cannot pass on the outcome of your decision: your message is not sent and its text stays in the message box. Send it again.
Occasionally an answer appears in full, but the assistant cannot save it to your conversation. It then shows This answer could not be saved to your conversation history. under the answer.
The answer itself is still correct and you can use it. Only the record of it is missing, so it would not be there the next time you open the conversation. You cannot rate an answer that was not saved, or report a problem with it.
Click Retry beside the note. Retry appears only on the latest answer, once the assistant has stopped writing.
Wait for the note to change. Saved to your conversation history. means the answer is now kept. Still not saved. Try again in a moment. means it is not, yet; click Retry again a little later.
When a conversation will not open
This conversation could not be found. It may have been deleted.— the conversation no longer exists, or the address belongs to somebody else's conversation. Your organization deletes old conversations automatically after a set time. Click New chat to start again.This conversation could not be loaded right now.— the conversation exists, but could not be read at the moment. Click Retry.
If something goes wrong while the assistant works on your question, it shows a shaded box with an icon, a title that says what kind of problem it was, and a sentence explaining what happened:
The assistant is unavailable— the assistant could not be reached.An OpenIAM lookup failed— the assistant could not read some of your information, for example your pending approvals.Too many requests— the assistant, or the service it runs on, is handling too many questions right now.Your session expired— you have been signed out.The answer took too long— the answer did not arrive in time.The assistant ran into a problem— anything else.
If your message is longer than your organization allows, the assistant shows Your message is too long. Shorten it and send it again. Your text stays in the message box, so you can shorten it and send it again.
What you can do depends on the problem:
Click Retry to ask the same question again.
When the box says
Too many requests, Retry stays greyed out and readsTry again inand a number of seconds, counting down. Wait until it becomes available, then click it.When your session expired, click Sign in again.
When the assistant could not read your information, the box may also offer a button such as Open Pending approvals, which takes you straight to that page so you can look for yourself. It appears only if that page is in your SelfService menu.
When the box says
An administrator has switched off the assistant's access to OpenIAM data, so it cannot look this up right now. You can still open the screen that shows it., it offers no Retry, because asking again does not help until the access is switched back on. Use the button to that page instead, when the box offers one. The assistant still answers questions that do not need your OpenIAM data, and about a minute after the access is switched back on, it can look your information up again.
Need help?
If a conversation still will not open, or answers keep showing that they could not be saved, contact your help desk or IT administrator. Tell them roughly when it happened and what you were asking about.
Last updated
Was this helpful?
