Validation and attribute scripts
Reject unusable rows before they are processed, declare which source attributes are read, and build the identifier an account carries in a target.
Applies to: OpenIAM 2026.8.1
Two small script types run alongside transformation during a synchronization, and a third builds the identifier an account carries in a target system. All three are short — most shipped examples are under twenty-five lines — and each prevents a problem that is expensive to unpick afterwards.
What this builds, and how long it takes
You get
A synchronization that rejects unusable rows, reads only the attributes it needs, and generates identifiers in the format the target expects
Time
30 minutes per script
You need
A deployment, a synchronization configuration, and a source containing rows you expect to fail
Reversible
Yes
Before you start
Transformation scripts is worth reading first — these run around it.
A source with some bad rows in it. A validation script that has never rejected anything has not been tested.
Build it
1. Validation scripts
A validation script decides whether an inbound row should be processed at all. It runs before transformation, once per row.
There are three return values, not two, and the third is the one most often missed:
ValidationScript.VALID
1
Processes the row
ValidationScript.NOT_VALID
2
Rejects the row and records it as a failure
ValidationScript.SKIP
3
Passes over the row without treating it as a failure
Use SKIP for rows that are not errors. A feed that carries every employee including those out of scope for OpenIAM, a header repeated mid-file, a row for a population another job owns — those are not defects in the feed, and returning NOT_VALID for them fills the failure count with noise that hides real problems. Return SKIP and the row is quietly left alone.
It implements an interface rather than extending a base class, so there is no inherited log and no caches. Declare a logger if you need one.
Use it for what makes a row unusable, not for business rules. A missing identifier, a malformed date, a header line repeated mid-file — those belong here. Whether a user should be provisioned belongs in transformation or in policy.
Rejecting is cheaper than repairing. A row that reaches transformation with a missing key can create an object that later has to be found and merged.
2. Attribute scripts
An attribute script declares which source attributes the synchronization reads.
as String[] is required. Groovy otherwise hands back a List, and the call fails at runtime rather than at compile time — which makes it slow to diagnose.
Naming them narrows the read. On a directory source in particular, asking for the attributes you use rather than everything is the difference between a synchronization that finishes and one that times out.
3. Principal generators
A principal generator builds the identifier an account will carry in a managed system — a distinguished name, a user principal name, a login.
That shape — isPerform and perform — is the policy map shape, because a principal generator is a policy map script specialized to the identifier. Policy map scripts explains both methods properly.
Read the shipped generators before writing one. cn_1.0.groovy for a directory common name, and userPrincipalName_1.0.groovy for Azure and Microsoft 365, are under conf/iamscripts/provision/. The format a target expects is exactly the kind of detail that is easier to copy than to derive.
4. Deploy them
Validation and attribute scripts go in the Groovy Manager under the folder for your synchronization configuration, and are referenced by name in that configuration. Principal generators go under provision/ for the managed system, and are referenced from its policy map. All compile on save.
Verify it
Run against a source containing rows you expect to fail.
Rows are being rejected
The synchronization result — a processed count lower than the source row count
The right rows are rejected
Log the identifier in the rejecting branch
Attributes are being read
The transformation sees them; log rowObj.columnMap.keySet() once
The principal is in the right format
The account in the target system
If it goes wrong
Every row is rejected
The condition is inverted, or the column name is wrong
Log the value being tested before the comparison
No row is ever rejected
The script is not attached, or always returns VALID
Confirm it is referenced by name in the synchronization configuration
An attribute is empty in transformation although the source has it
It is not in getAttributes()
Add it
getAttributes fails at runtime with a cast error
The as String[] coercion is missing
Add it
A principal is generated in the wrong format
The target expects a different one
Compare against the shipped generator for that target
Accounts are created with duplicate principals
The generator produces the same value for different users
Include something unique; the shipped generators show how
What this procedure does not cover
The matching rules that decide which existing object an inbound row corresponds to — those are configuration, covered in the Administration Guide, not a script.
Related
Transformation scripts — what runs after validation
Policy map scripts — the
isPerform/performpattern in full
Last updated
Was this helpful?
