How scripting works
The script types, where each one runs in a flow, what it receives, and the conventions every script follows.
Applies to: OpenIAM 2026.8.1
OpenIAM's extension points are Groovy scripts. They run inside the platform's JVM, inside its Spring context, and are compiled when you save them.
Read this before any tutorial. The script types differ in what they extend, what they receive and when they run, and most mistakes come from applying one type's habits to another.
The script types
Policy map
A class extending AbstractIPolicyMapGroovy
Provisioning an account into a managed system, per attribute
Transformation
A class extending AbstractUserTransformScript, AbstractGroupTransformScript or AbstractRoleTransformScript
Synchronization, once per inbound row
Validation
A class implementing ValidationScript
Synchronization, before transformation, per row
Attributes
A class implementing AttributesScript
Synchronization, to declare which attributes are read
Reconciliation
A class extending a reconciliation command base class
Reconciliation, when a situation is matched
Policy map is the type you will write most. Across the scripts shipped under conf/iamscripts/, AbstractIPolicyMapGroovy accounts for more than five times the next most common base class. Transformation is the easiest to learn, which is why the tutorials start there, but policy map is where the volume is.
Where each type runs
Synchronization — reading identities from a source into OpenIAM:
source row
-> AttributesScript which attributes to read
-> ValidationScript is this row usable?
-> TransformScript map the row onto a ProvisionUser / Group / Role
-> OpenIAMProvisioning — pushing an account out to a managed system:
Reconciliation — comparing OpenIAM against a managed system: a situation is matched, and the command script bound to that situation runs.
Batch — a scheduled task runs a script on its own, with nothing handed to it.
Conventions every script follows
The class name matches the file name. MemberOf_1.0.groovy declares class MemberOf — the name before the version suffix.
The version is in the file name. ScriptName_1.0.groovy. When you change a script that is in use, increment the version rather than editing in place. It gives you something to go back to, and the Groovy Manager keeps both.
No package declaration. The large majority of shipped scripts have none, and those that do use no single convention. The platform identifies a script by name and folder.
A logger is usually available. Transformation base classes expose log. Policy map and reconciliation scripts in the shipped set typically declare their own with LogFactory.getLog(...). Either works — do not declare one that shadows an inherited one.
Spring beans are reachable, and how depends on the type. Class-based scripts use @Autowired or an injected context field. Batch scripts receive the context through a binding variable. Each tutorial shows its own.
What a service call returns
Scripts call the platform's services directly, and those services answer with Response — the internal service envelope. It is not the envelope the REST API returns, so a pattern you learned from an integration does not carry over.
status
SUCCESS or FAILURE
errorCode
A ResponseCode — 554 values, and specific
errorText
Human-readable detail
fieldMappings
Which field failed validation, and why
errorTokenList
Structured detail where an operation produces more than one error
rootCauseText, stacktraceText
Diagnostics
isSuccess() is the convenient check:
Check every service call. A script that ignores the response continues on the assumption that the call worked, and the failure surfaces later somewhere that does not point back at the script.
Do not swallow errorCode. Log it as it comes. A code you have never seen is more useful in a log than a message you substituted for it.
A caller reaching the platform over REST sees a different envelope — API fundamentals sets out which endpoints return which.
Where scripts live
In the platform, not on disk in your project. Two ways in, and they are not equivalent:
Where
Webconsole → Administration → Groovy Manager
conf/iamscripts/ on the server
Use for
Creating, editing, importing and exporting
Bulk seeding, and reading the shipped examples
Compiles on save
Yes, with the error shown in the editor
No
The folders under conf/iamscripts/ are the taxonomy the Groovy Manager presents:
provision/
Policy map scripts, per managed system. The largest set by far
sync/
Transformation, validation, matching and attribute scripts
recon/
Reconciliation scripts
batch/
Batch task scripts
bpm/, workflow/
Workflow scripts
AM/, idp/, oauth/, uri/
Access management, identity provider and federation
selfservice/, webconsole/, ui-template/
Interface behavior
mail/, language/, geo/, reports/
Notification, localisation and reporting hooks
prov-helper/, business-rules/, request-attributes/, user-conversion/
Shared helpers
Read the shipped scripts. They are production code, and they are the best reference available for every pattern in these tutorials.
Testing
There is no local test harness. Scripts depend on the platform's Spring context and its injected services, so they are exercised by deploying them and observing them.
What you do locally is compile — Set up your environment covers a project that catches a wrong type or a missing method before you deploy. What you do on the platform is covered per type in each tutorial: how to trigger it, and where its output appears.
Related
Transformation scripts — the easiest type to start with
Policy map scripts — the type you will write most
Last updated
Was this helpful?
