Choose what you are building
Match what you are trying to build to the pages that build it, in order.
Applies to: OpenIAM 2026.8.1
Find what you are doing, then follow the pages in the order listed. The pages are shared between routes — the procedures are not duplicated.
Groovy scripting
Control what an attribute contains in a target system
Map an inbound feed onto OpenIAM users, groups or roles
Reject bad rows before they are processed
Act on what reconciliation finds
Run something on a schedule
Build the identifier an account carries in a target
Read How scripting works before any tutorial. The script types differ in what they extend, what they receive and when they run, and most mistakes come from applying one type's habits to another.
The REST API
Call the API for the first time
Create, update or deprovision a user
Handle tokens — refresh, revoke, sign out
Find a specific endpoint
API fundamentals, step 4, Find the endpoint you need
Integrate from Python or Java
Understand why a call was refused
Which script type do I need?
If you are not sure which extension point applies:
What value lands in a target system's attribute
Policy map
Whether an attribute is written to a target at all
Policy map
How a source row becomes an OpenIAM user, group or role
Transformation
Whether a source row is processed at all
Validation
Which attributes are read from a source
Attributes
What happens when OpenIAM and a target disagree
Reconciliation
Something that runs on a schedule with no input
Batch
Policy map is the type most projects write most of. Across the scripts that ship with the platform, it accounts for more than five times the next most common type.
Related
The Administration Guide — configuring the things these scripts hang off
Last updated
Was this helpful?
