Skip to content
For the complete documentation index, see llms.txt. This page is also available as Markdown.
Error and symptom index
Every error message, log line and observable symptom the guide explains, with the page that explains it.
Applies to: OpenIAM 2026.8.1
What this is, and when you need it
Search this page for the exact text you were given — an error on screen, a line in a log, or the behavior you observed — and follow the link to the page that explains it. Strings are reproduced as the product emits them, including any misspellings, so search for what you see rather than what it should say.
You are seeing
What it means
Where it is explained
(Default approver)
Appended to an approver's name on a task: this step's own approver resolved to nobody, so a required step fell back to org.openiam.idm.activiti.default.approver.user
AD user Status: true ====
The PowerShell enabled row decided the account should stay enabled, ignoring secondary status
AH01144: No protocol handler was valid for the URL /app/ (scheme 'https')
mod_ssl is not loaded, so SSLProxyEngine on was never applied and Apache cannot reach an HTTPS upstream
ANOTHER_SAVE_IN_PROGRESS
Another thread or node holds the save lock for this user, usually because a script started a nested operation
Ambiguous method overloading for method org.openiam.exception.BasicDataServiceException#<init>
A catch block passed a null second argument, usually e.getMessage() on an exception with no message
An attempt was made to add an object to the directory with a name that is already in use.
Another object holds the same RDN in the target container, and it need not be a user
Are you sure you want to link the selected items? Existing identities will be overwritten.
The link confirmation, warning that the replace branch will overwrite an existing login value
Attribute Map is inactive or name is empty!
The row was skipped because Status is unchecked or Attribute name is blank
CANNOT_INSTANTIATE_GROOVY_CLASS
A validation script failed to compile, failed the cast to the validator interface, or threw something other than BasicDataServiceException
CANT_ADD_YOURSELF_AS_CHILD
A role was added as its own child; longer cycles are not detected and will save
Can't get SSO Attibutes
One attribute threw and cleared the entire AttributeStatement, so the SP sees an assertion with no attributes (the misspelling is in the source)
Can't invoke spring thread
The named Spring bean is not in the batch-task-manager context, or the invocation threw
Can't renew token via restful call
Explicit session renewal failed and answered 500
Can't save AuthnRequest from SP
Parking an inbound AuthnRequest in Redis failed, so it cannot be replayed after authentication
Can't schedule task:
The sweep threw while materialising one task's next runs
Cannot execute batch groovy task
The batch script threw, or returned something that is not an Integer
Cannot get identity from cert
The ESB's certificate-to-identity call failed; the specific ResponseCode names which configuration step is wrong
Cannot instantiate <scriptId>. Using default
The connector response handler script could not be loaded, so the no-op default ran instead
Cannot instantiate null
The pre- or post-processor script could not be loaded or cast, so the no-op default ran instead
Cannot invoke "org.openiam.idm.srvc.auth.dto.LoginLockMarkerEnum.toString()" because the return value of "org.openiam.dto.Login.getLockMarker()" is null
Creating a user from an orphan; the login bean carries no lock marker and the diff dereferences it unguarded
Could not determine authentication level grouping for
A URI pattern matched but no authentication level grouping resolved for it — a gap on the pattern, not an entitlement decision
Could not initiate workflow
The workflow service failed, or returned nothing, when the screen asked it to start a request; the message carries no reason of its own
Could not parse certificate: java.io.IOException: Empty input
The gateway posted an empty certificate body to the ESB, so the client certificate never reached the module
Could not put value for attribute map <name>
The row's script threw, or an IDM-value row resolved to blank; the cause follows on the same line
Current step has been auto approved because requester is an approver or part of approver group
The requester was in the candidate list for the next level, so that step was completed without a task
Data Key is null. Skipping decryption...
The ESB had no data key for the value it was asked to decrypt — commonly a sign-in attempt for an identity that does not exist
Entity reindex initiated. This operation may take several minutes if there are many records.
A reindex was accepted; an acknowledgement, not a completion
Exception Occurred during RabbitMQ Call
The generic MQ listener wrapper; the real cause is the exception logged beneath it
Exception occurred during batch tasks execution
The scheduler caught a Throwable and abandoned the rest of the cycle, so no task ran
FATAL ERROR. No Authentiation Provider was found for the current HTTP Request. There is also no any default providers in DB also.
This UI instance has no authentication provider cached for the request and no default to fall back on, usually because a sweep ran while the ESB was unreachable
File Access exception
A script tried to write outside iam.files.location
HELPDESK_SECURITY_ANSWERS_ARE_WRONG
One or more help-desk answers was wrong; the response never says which
HELPDESK_TOO_MANY_FAIL
The caller's SECRET_FAIL_COUNT passed FAIL_ATTEMPTS_HELPDESK; only a correct answer set or a manual update clears it
HHH000443: Dialect [org.hibernate.dialect.SQLServer2016Dialect] limits the number of elements in an IN predicate to 2100 entries.
The Hibernate warning preceding the same failure; the entry count is the size of the backlog
Ignoring 'myCustomAttr' attribute for modifying user because no special rule defined for it and isUnknownAttrBindAllowed is not set as well
The Active Directory connector dropped an attribute whose name is not on its allow-list
Invalid Login and/or Password
The sign-in failed; OpenIAM deliberately never says which half was wrong, so this is not evidence the account exists
Is proxy request - using cookie from proxy
The UI deliberately did not renew the session cookie because the request arrived through the gateway, which owns it
LdapErr: DSID-0C091211, comment: Error in attribute conversion operation, data 0, v3839
A value reached a binary directory attribute in the wrong form, usually a pre-encoded password
Login already exists
A different user already holds that login on that managed system
Logins were successfully updated or added to the user
The link was queued, not confirmed stored
Meta rule '<name>' requires a Content Type
A Form Post Processor metadata entry was saved with Content Type blank; the gateway cannot encode a request body without it
Mail not sent, invalid notificationType
No enabled MAIL_TEMPLATE carries the name the sending feature asked for, usually because the template was renamed
Maximum retry count exceeded. Operation interrupted. Message queue is <queue>. RabbitMQ exchange is <exchange>
The requeue ceiling was reached and the operation was abandoned; the underlying save never succeeded
The save was re-queued org.openiam.rabbitmq.message.max.retry.count times and never got the lock
NOT_ENOUGH_DATA_TO_BUILD_HELPDESK_QUESTIONS
The caller has none of the built-in candidate values and the attribute property is empty, so no questions could be built
NOT_FOUND - failed to perform operation on queue <queue> in vhost <vhost> due to timeout
The broker holds the queue but the node that owns it is not serving it — queues that stopped synchronizing across the cluster present this way, and a service that needs one fails to start
NO_ACTIVE_EMAIL_CONFIGS
No mailbox configuration is active, or the only active one is nominated as another configuration's failover and is therefore excluded from the rotation
No attribute named 'lastSAMLMessageId' found for the current session
The cookie correlating a sent AuthnRequest with its response did not come back; its path is a literal /idp/saml2/... string
No such property: getMessage for class: java.lang.Object
A Groovy script leaning on def where an explicit type is required
Not allowed to change your own entitlement
The signed-in operator tried to change their own entitlements while org.openiam.ui.webconsole.allow.change.own.entitlements is false
PRECONDITION_FAILED - delivery acknowledgement on channel <n> timed out. Timeout value used: 1800000 ms
One request held a consumer longer than the broker's delivery-acknowledgement timeout, so the broker closed the channel — the consumer's working time, not OpenIAM's reply timeout
Page template was null. Perhaps, this page was rewritten into React.
Debug-only line behind a screen that renders with no fields
Parameter value [INTERNAL_EMPLOYEE] did not match expected type [org.openiam.idm.srvc.meta.domain.MetadataTypeEntity (n/a)]
A user search filtered on employee type against the database path, which cannot bind that field
Pattern <patternId> mapped to multiple templates - can't fetch template.
The service-side log line for the same ambiguous binding
Pattern <patternId> with MetadataType <typeId> mapped to multiple templates - can't fetch template.
Same ambiguity, hit on the pattern-plus-metadata-type lookup
Please select both orphan accounts and a user before proceeding
Update Identities pressed with only one side of the link selected
RESOURCE_TYPE_NOT_SUPPORTS_HIERARCHY
The resource type named in the message ships SUPPORTS_HIERARCHY='N' and cannot take a parent or child
SAML_USER_NOT_AUTHORIZED_TO_SSO
The user is not entitled to the authentication provider's resource; creating the provider grants nothing
Save is in progress. Send message back to <queue> queue. RabbitMQ exchange is <exchange>
A directly submitted save was re-queued to wait for the user's lock
On the operation's audit event: another save of the same user was running, so this message was requeued and will be retried
The incoming request has too many parameters. The server supports a maximum of 2100 parameters. Reduce the number of parameters and resend the request.
SQL Server's parameter cap, hit by the scheduler marking every due schedule row for one task
This page is linked to more than one template. Each page must be linked to exactly one template.
Two page templates resolve for one URI pattern and metadata type
Trigger returned null next execution time for task
The cron expression has no future fire time, so no schedule row is created
URI Fedration. Proxy URI:
The ESB's per-request authorization decision, carrying the matched pattern, the error code, the upstream and the time it took (the typo is in the source)
URI Pattern ID: <patternId>, Content Provider ID: <cpId>, is From Proxy: true.
The UI recording which pattern and content provider the gateway resolved for this request
URI Syntax Exception:
The proxied URL is not a legal URI, so the authorization call failed with INVALID_URI before any pattern was evaluated
Unable to reindex the selected entity
The reindex request failed
User already has an identity for this managed system
The user you are linking to already has an identity there
User with id <userId> is saving in another thread. Current request will be sent back to the queue to be retried.
The error token behind ANOTHER_SAVE_IN_PROGRESS; a save from provisioning is not actually retried
[userAccountControl]: 514
The enablement row computed "normal account, disabled" from the user's two statuses
[userGroups]:
One line per group the membership script did send, carrying that group's distinguished name
can't allocate 105 tokens
Reported in the field during certificate authentication as the module failing to parse the ESB's JSON response; the count varies and the cause is not established in source
errorCode=UNAUTHORIZED
Within that line: a pattern matched but entitlement or an authentication level refused the request
is Entitled. Time: <ms>. User ID: <id>. Resource ID: <id>
In the auth-manager log at debug: one entitlement check, with the time it took and the user and resource it was for
isUnknownAttrBindAllowed flag is set - appending 'myCustomAttr' attribute with 'somevalue' value to additional object attributes
The connector is binding an unrecognised attribute because the managed-system flag is on
javax.persistence.EntityNotFoundException: Unable to find org.openiam.idm.srvc.batch.domain.BatchTaskScheduleEntity with id <id>
Raised by BatchTaskListener in the ESB log on every attempt to save a batch task: the Hibernate second-level cache still holds a schedule row that has left BATCH_SCHEDULE
not valid - doesn't start with a '/' - XSS detected. Returning 401
The postback URL failed validation, so the login page returned 401 instead of redirecting
there is no DN for group
A group was skipped because it carries no dn attribute, so it could not be named to the directory
memberOf_1.0.groovy walked a group attribute that is not named dn; it is logged even for groups that do have one
there is no groups
The membership script had no direct group memberships to send, so the account's group attribute went out empty
Last updated
Was this helpful?
